603,400 active members*
2,554 visitors online*
IndustryArena Forum > CAM Software > Mastercam > I'm confused trying to save a file.
    Oct 2004
    84
    I have X9 and when I try to save a drawing as a DXF (Autocad) file, it shows up as a 3D Builder file.
    When I try to open the 3D Builder file, I get a message that I don't have a 3D object defined with a triangle mesh and I can't open the file. I don't even want to open the file.
    I want a DXF file that I can email to a friend to make the part I have drawn in X9.
    Like the Led Zeppelin song, I'm dazed and confused.... and need help.
    Thanks,
    Doug
    Dec 2008
    3211
    Re: I'm confused trying to save a file.
    Quote Originally Posted by Dugg View Post
    What do you mean by "3D Builder file" ? ...... Google tells me it is a 3D printing application
    - that extension is probably ( mistakenly ) associated to incorrect software
    ---- try using R-click on the file and use the "Open With" option ( select "Mastercam X9" as default ) to re-open the DXF to check the file's content integrity
  1. Part to STL file save
    By SPEEDRE in forum Solidworks
    Last Post: 05-11-2011, 02:33 PM
  2. How to save file
    By mark296 in forum Fanuc
    Last Post: 11-06-2008, 08:45 AM
  3. Save as .tap file in V20?
    By FL Knifemakr in forum BobCad-Cam
    Last Post: 10-01-2007, 09:09 PM
  4. file save problem
    By bobcor in forum BobCad-Cam
    Last Post: 03-01-2006, 04:37 PM
  5. File/Save as seperate
    By daking in forum NCPlot G-Code editor / backplotter
    Last Post: 01-15-2006, 02:41 AM
