I have loaded KmotionCNC 4.34h which features the split screen option showing both gcode, and the viewer on the same screen.
I love the new version but have a basic question.
My monitor has a screen resolution of 1280x1024
When I start up KmotionCNC and then go to Tool Setup, and then go to the tool setup files tab
In the main dialogue Face I select Custom,
Then under Screen Script File, I select DualPane3AxisView1024x768
This bring up the new screen set and I can select Split, View, or Code and that all works fine.
This screen takes the entire screen with no border, which seems strange since my monitor has 1280x1024, so I must be doing something wrong.
The only issue is when you can not see the board there is no easy way to close the application?
Russ
