603,373 active members*
3,858 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Laguna Smartshop Maker - RichAuto B57 controller help
    I'm having issues when accessing internal files on the controller. The controller just hangs up when I try to access 'Files'.
    I've also, so far been unable to access the files via USB/PC connection. Anyone have insight?
    Re: Laguna Smartshop Maker - RichAuto B57 controller help
    Quote Originally Posted by Jtluttrell84 View Post
    If the internal storage is nearly full, it might cause slow performance or freezing when accessing files
    Quote Originally Posted by cncmakers001 View Post
    I suspect this may be the case and why I was hoping to access the files via PC, but I have never successfully been able to do this. As a second option, there is the "Inner Format" option.
  1. Misrepresented Laguna Smartshop Laser (MX, EX,...)
    By HoS2020 in forum Laser Hardware
    Last Post: 08-21-2021, 07:59 AM
  2. Laguna Smartshop 2 HELP!
    By bsawler in forum Commercial CNC Wood Routers
    Last Post: 04-28-2021, 01:29 PM
  3. Laguna Smartshop I Alarm codes
    By Nailzscott in forum Chinese Machines
    Last Post: 08-14-2020, 01:44 AM
  4. Laguna SmartShop 1 Transformer Problem
    By cormacktimothy in forum Commercial CNC Wood Routers
    Last Post: 09-02-2019, 03:10 AM
