603,385 active members*
3,947 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion
IndustryArena Forum: Linear and Rotary Motion
Page 9 of 131 78910111959109
Threads 161 to 180 of 2609
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede, 03-01-2005 05:06 PM
    8 Pages
    1 2 3 4 5 ... 8
    06-25-2025, 03:36 PM Go to last post
  2. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid, 02-05-2006 08:37 PM
    4 Pages
    1 2 3 4
    cnc, cutting, plasma, run, servo, wan
    08-06-2021, 02:21 PM Go to last post
    03-16-2021, 08:26 PM Go to last post
  1. bk12 bearing eplacement
    Started by NicMarsha11, 09-24-2020 06:27 PM
    10-01-2020, 09:28 AM Go to last post
    10-01-2020, 12:49 AM Go to last post
  2. Ball screw maintenance
    Started by NicMarsha11, 09-19-2020 04:14 PM
    09-20-2020, 04:11 PM Go to last post
  3. ball screw questions
    Started by mechhamo, 08-31-2020 12:10 AM
    2 Pages
    1 2
    axis, ball, lead, screws, software
    09-10-2020, 11:43 PM Go to last post
  4. Screw diameter and strenght relation
    Started by PropellerHat, 08-13-2020 01:38 PM
    09-08-2020, 08:01 AM Go to last post
  5. Suggestions on linear rails
    Started by Panovak, 01-27-2020 06:26 PM
    cnc, linear, rails, router, suggestions
    09-05-2020, 04:24 AM Go to last post
  6. 20mm ballscrew mounting question.
    Started by geroge, 02-02-2020 11:25 PM
    ballscrew, bk15/bf15, end, mounting, supports
    09-05-2020, 04:21 AM Go to last post
  7. Strange surface pattern in x axis only?
    Started by Ritzy321, 09-05-2020 01:42 AM
    09-05-2020, 03:19 AM Go to last post
  8. Lightbulb Manual Lathe to CNC Conversion
    Started by KelloggsResearchLabs, 09-02-2020 07:23 PM
    09-03-2020, 09:30 PM Go to last post
  9. Switching Power Supply Stepper Motor
    Started by Andrewxxd1, 09-01-2020 09:49 PM
    idea, sources, stepper motor, switching, switching power supply
    09-02-2020, 08:02 PM Go to last post
  10. Non-Gummy Way Lube for milling machine???
    Started by Flyboy771, 08-23-2020 08:45 PM
    2 Pages
    1 2
    08-29-2020, 03:32 PM Go to last post
  11. The Design and Construction of a 'Backlash-Free' Rotary Table
    Started by RCaffin, 02-28-2015 11:11 AM
    6 Pages
    1 2 3 4 5 ... 6
    08-20-2020, 05:58 AM Go to last post
  12. Chinese bearing company
    Started by sikus, 04-27-2010 10:16 AM
    07-03-2020, 01:08 PM Go to last post
    06-28-2020, 05:22 AM Go to last post
    06-20-2020, 12:40 AM Go to last post
  13. Ballscrew position in between linear guide rails
    Started by sh2005, 06-15-2020 07:36 AM
    06-19-2020, 10:00 PM Go to last post
  14. RM1610 Ballscrews, are they CW or CCW?
    Started by kolias, 05-30-2020 04:39 PM
    06-01-2020, 01:12 AM Go to last post
  15. Help Needed With Automatic Lubrication
    Started by jimskeet, 05-24-2020 08:23 AM
    automatic, bearings, cnc, forum, lubrication
    05-25-2020, 07:15 PM Go to last post
  16. 1610 ball screws on a 6040 sized DIY machine
    Started by Sterob, 05-04-2020 10:45 AM
    ball, bed, diy, screws, sized
    05-05-2020, 12:46 AM Go to last post
    04-26-2020, 05:01 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 50 users browsing this forum. (0 members & 50 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
