588,169 active members*
4,397 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Little help from mazak users using EIA/ISO programing
Results 1 to 4 of 4
    Jun 2005
    36
    Hello all
    I have been a member for many years I can usually search and find what I am looking for but couldn't this time so here is my first post!
    I am trying to help out a nearby shop that purchased a Mazak V-20. It is a 1985 vintage with the M-2 control. They bought it to run somewhat complicated casting on it. They have asked me to help program and get them going. I have not been on a Mazak for almost 10 years and would rather program on Mastercam than Mazatrol. I am writing a post for Mastercam and would like a little info from some users. This is what I need. Basically it is so I can get the tool changes right.
    How is the tool changes called out? from what I seen in the manuals they gave me Txxx and M06 can not be called in the same block. How do you set up next tool? Can I use G91 G28 Z0. call before the tool change? Do I need to send X and Y too?
    This is the way I was setting up but would like to verify before I run on machine
    (First tool change)
    T10
    G91 G28 Z0.
    M06
    T11 (next tool)
    (all other tool changes)
    G91 G28 Z0.
    M06
    T12 (next tool)
    Any input would be appreciated.
    Jerry
    Nov 2009
    82
    tool changes
    Some machines need to load the tool into the "Pod" first. Although I can't be positive I would try calling up the tool first.
    T#(should get tool ready in changer)
    Then M6 to perform the change.
    You should then be able to call up the next tool to be used later in the program.
    The G91 G28 Z0 may not be the tool change position either.
    Dec 2007
    300
    Smile
    Below are two examples for M+ or M32, M2 should be similar. First one uses G28 second one uses G30. Sometimes M06 needs to be on the same line others it is on a separate line. Try them until you find one that works. (note: these programs are for using Mazatrol Tool Data for offsets! no G43 D-H is used)
    O00000001
    G00 G40 G80 G90
    N1 M6 T01 (5G ISCAR MILL)
    S3056 M03 T02
    G00 G54 X5. Y-2.7198 B0.
    M08
    Z4.
    G95
    Z.15
    G01 Z0. F.06
    X-6.22 F.004
    G02 Y-2.25 R.2349
    G01 X5.
    G00 Z4.
    M5 M9
    G91 G28 Z0
    9
    N2 M6 T02 (1.66B SAE-12 ALLIED)
    M1
    S1553 M03 T03
    G00 G90 G54 X-1.3 Y-3.3 B0.
    M08
    Z4.
    G95
    etc..........OR
    (======= START OF PROGRAM =======)
    N100 G20
    N102 G0 G17 G40 G80 G90 G95
    (3/4 BALL ENDMILL TOOL26 DIA .750 )
    ( FAR SIDE ROUGH .025 STK )
    N104 G30 G91 Z0. Y0.
    N106 T26
    N108 M6
    N110 T1
    N112 S10000 M3
    N111 G61.1
    N114 G0 G90 G55 X2.338 Y6.1892
    N116 Z2.5 M8
    etc
    Jun 2010
    14
    on my nexus 410 i program a tool call in iso like this it is safe aswell
    N1 G00 G90 M09 (ABOSOLUTE POSITIONING)
    G53 Z0 M05 (RETURN TO SAFE MODE)
    T1?? (PRE CALL TOOL)
    M06 (TOOL CHANGE)
    G00 G90 G55 X? Y? M03 S????(POSITION TOOL TO START OP)
    G00 Z5? (RAPID TO POSITION REQ)
  1. mazak users
    By 585integrex1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2019, 04:39 PM
  2. EIA programing on a mazak 350 with c axis
    By the mill kid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-30-2009, 01:15 PM
  3. Mazak Lathe SQT15 programing help
    By Machsol in forum G-Code Programing
    Last Post: 08-01-2008, 07:35 AM
  4. programing help
    By DARKWINZ in forum Okuma
    Last Post: 06-03-2008, 03:23 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
