587,267 active members*
3,473 visitors online*
    Dec 2004
    312
    M32 42 Parameter error
    Hi All,
    I have Mazak AJV 18 that was disconnected for over 4 months and we just powered it back up and installed new batteries
    we followed the procedure from http://www2.i-logic.com/manuals/Maza...0Procedure.pdf and we were able to do up to step 3 and now it wont let me go past that point..
    the fault code says "An error(s) is included in the machine parameter settings for the servo system."
    I have attached the images of what I see at the moment if that helps
    Dan
    Attachment 336558Attachment 336560Attachment 336562
    Mar 2009
    109
    Re: M32 42 Parameter error
    Did you load parameters?
  1. Fadal VMC 15 error parameter error
    By jerodor in forum Fanuc
    Last Post: 06-12-2014, 05:22 AM
  2. 8055T v3.13 E-504 error in parameter
    By captain_bas in forum Fagor Automation
    Last Post: 12-30-2012, 08:02 PM
  3. 63 parameter error
    By FN Smith in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2010, 07:16 PM
  4. machine parameter error
    By Runner4404spd in forum Fadal
    Last Post: 03-06-2009, 04:33 AM
  5. Memory Parameter Error?
    By John3 in forum Fanuc
    Last Post: 09-07-2007, 03:17 PM
