You guys lost me on this!
What does a battery operated edge finder have to do with the tormach din connector for probes?
Sorry it does help to watch the videos. Setting here with watching boring cam simulations and checking dimensions on cad system. takes up most my system so I'm reading not watching much
Hi mountaindew
unless you have a spark erosion machine to "drill" a blind hole in a 10mm ball bearing
to add the attachment point for the spring
the Chinese probe just provides some inexpensive parts for narrobb's project
Attachment 385442
John
Hi guys,
Digging this thread up as I was wondering what resistor values would be required to make this work with a 24vdc power supply?
I have a UCCNC + AXBB-e setup on my mill, the probe input terminals run on 24vdc.
The main question is what voltage the input on your probe port wants to see, and whether it's current operated like the Tormach one.
If it can tolerate 24V, then you can bump up the LED resistor to maybe 2.2 kOhm or so, although details depend on the input impedance of your probe port.
However, if it can't tolerate 24V, you will need to also add a voltage divider of some sort, so the circuit would need to be different. And if it's not current operated, then you'd ALSO need a different circuit.
Thanks for the reply jwatte.
These AXBB-e boards want to see 24vdc on the isolated inputs port. I have wired up my limit/homing switches (and the rest of the machine really), exactly as shown in the manual below and it works great.
My knowledge of electronics is a bit limited when you start talking of impendance and voltage divider circuits unfortunately. I can build/solder circuits no worries, but not really design!
If the input is 24V tolerant, then the same circuit as below, but perhaps with 2.2 kOhm resistor, should work fine!
Fine-ish, actually -- the diode will have some voltage drop, and the resistor will also have some voltage drop.
Depending on the input impedance of the "24V" input, you may need to change the resistor; there's no way to know for sure without knowing the specification of the input.
Unfortunately, the diagram doesn't specify, so it's impossible to know for sure.
