587,278 active members*
3,335 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Need help with error code on MC-4VA 201-X Alarm A Servo Amp 2E6 X axis
    Nov 2013
    26
    Hi. I recently purchased this 1989 MC-4VA and have run into an issue with the X axis.
    On startup, it shows the error code 201-X Alarm A Servo Amp 2E6 on the X axis.
    It tripped the breaker on the board one time, but not always.
    We used a megger to check the motor windings and wiring, but it tested fine.
    I am getting an error LED as shown on the drive.
    Can anyone tell me what this alarm code and LED means and how to troubleshoot?
    Many thanks!!!
    Attachment 493730
    Attachment 493732
    Re: Need help with error code on MC-4VA 201-X Alarm A Servo Amp 2E6 X axis
    Quote Originally Posted by bryanbdp View Post
    Many thanks!!!
    Attachment 493730
    Attachment 493732
    The X axis servo driver should be broken.
    You can swap a driver from other axis to confirm it.
    Mar 2007
    84
    As previously mentioned problem is with X axis servo driver. On BL-D**A board I see that red "VR" LED is lit on- from manuals it means that there is a problem with SVC-A board (top one). First check if the fuses are ok (they are located near connectors CN2 and CN3). If they are burnt it could be a sign that base unit transistor drivers are bad and should be replaced. Another things to check- base unit transistor module, and all electrolythic capacitors on driver.
  1. 201-8 alarm a servi amp ma-axis 2E6
    By Aylmer in forum Okuma
    Last Post: 08-02-2017, 06:32 PM
  2. Okuma MC-4VA - 201-Z Alarm A Servo Amp 2E6
    By treehick in forum Okuma
    Last Post: 06-14-2017, 12:46 PM
  3. Replies: 3
    Last Post: 04-23-2015, 08:19 PM
  4. Replies: 4
    Last Post: 09-12-2011, 07:10 PM
  5. error code 201
    By koppjb in forum Milltronics
    Last Post: 01-14-2010, 06:02 PM
