603,379 active members*
3,644 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Need help with R2020 tuning please.
    Mar 2010
    3
    I've got the following hardware:
    Controller: R2020 connected to the parallel port interface as described on Rutex site.
    Encoder: US Digital E5S-50-250-IEG.
    Encoder interface: Rutex R2210 board connected to the R2020 via a short cat. 5 cable.
    Motor: MCG23902, running only at Vm = 24 V for testing at this stage, at reduced speed.
    The Rutex-supplied Windows software seems to be working fine, it's communicating with the motor and I can spin up the motor using the test profiles.
    I'm following the document which describes the tuning on the Rutex website. It's all good until I get up to the point of adjusting Kp, with Ki and Kd both equal to 0, and my loop time equal to 500 uS. I can't get to any point where I'm recreating anything that looks like the oscillation response as is shown in the Rutex guide.
    Can anyone help? Any ideas what ball-park value my Kp should be set to for a motor like this?
    Regards.
    Oct 2005
    80
    Tuning R2020
    The settings for P, I , and D will depend greatly on the motor you have. If your profile looks like a hill without a plateau, then you need to keep increasing your P. Keep increasing it until you get oscillation. The value could be quite large to get to this point.
  1. Rutex R2020 and Fanuc 20M servomotors
    By maquiza in forum Servo Drives
    Last Post: 02-22-2016, 09:23 AM
  2. PID Tuning R2020 Large SEM Motors
    By UKRobotics in forum Servo Drives
    Last Post: 04-07-2009, 12:02 AM
  3. Options for resetting faults on R2020
    By mecheng10 in forum Servo Drives
    Last Post: 05-07-2007, 02:02 AM
  4. R2020 Rutex connected to Siemens motors.
    By Darc in forum Servo Motors / Drives
    Last Post: 09-08-2006, 11:45 PM
  5. Can the R2020 drive this motor?
    By Jeroenvanderloo in forum Servo Drives
    Last Post: 05-17-2006, 10:58 PM
