Originally Posted by
guy2b1
I have existing 3 stepper motors and 3 stepper drivers with 12volts 10amps power supply, how can I rapid speed my stepper motors? I notice the movement is kinda slow using 13 TPI threaded rod.
Also I finally received my new 3 pieces of stepper driver with microstepping, which pin should be assigned to the parallel port from pin 1-25? I will continue to finish my CNC project. I do not know which pin will I connect 4-X2 and 5-Off to the parallel port
Driver 1
1. 5V - Pin 1
2. Clock - Pin 2
3. Direction - Pin 3
4. X2
5. Off
6. Ground - Pin 18
Driver 2
1. 5V - Pin 1
2. Clock - Pin 4
3. Direction - Pin 5
4. X2
5. Off
6. Ground - Pin 19
Driver 3
1. 5V - Pin 1
2. Clock - Pin 6
3. Direction - Pin 7
4. X2
5. Off
6. Ground - Pin 12
Please help me with these pin assignments to parallel port
Off should be disable, and can probably be ignored, but you did get a manual with those drives?
X2 sounds like some sort of step multiplier, but that is just a guess.
I just picked up one of those motors and to make it go faster try wiring it half coil. If you are using it full coil and ignoring the other 2 wire it is the same as series winding and it will be slow with lots of torque. Half coil means use an outside wire and the center wire from each coil, not the both outside wires.
I will be trying this out next week and will get back to you if you don't try it first.
Mariss of gecko shows the proper way to do it , either here on the zone, or on the gecko website.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
