603,796 active members*
3,959 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > OTC, reloaded param, now not retaining position with absolutes
Results 1 to 4 of 4
    Nov 2006
    303
    I had to reload my Mori SL-15 with OTC. Got the backup direct from Mori. Everything works except when I home the machine, it zeros fine but when I walk away from the limit and turn machine off, when it fires again, it says X0, Z0. This machine has absolute encoders on it (red cap) and usually does not need a zero return before making parts. Mori is baffled at this point. Everything else works though. Jogs fine, spindle runs fine, etc. Just not sure on this one...
    May 2009
    181
    what does parameter 1815 look like..
    Feb 2009
    6028
    Parameter 1815 on a 0 control? He got it fixed in his other post for Mori
    Nov 2006
    303
    ^^^ what he said. You are on the right track with param 1815. The 0 is param 21 which were not set for absolute encoders for some reason. My backup settings were right but for some reason param 21 was not right. I went ahead and zeroed out param 22 so when I get it loaded next time, it will alarm for needing a zero return and that should be easier than having to bypass the soft limits when first firing up.
    All in all, things went smoother than I expected but should be a 10 min deal next time.
  1. retaining cap
    By grogsroom in forum Hypertherm Plasma
    Last Post: 01-10-2010, 02:32 PM
  2. T-4 Parameters reloaded - now not working
    By serickson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2009, 04:02 PM
  3. Retaining tabs
    By ssozonoff in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-05-2009, 10:43 AM
  4. retaining thread lead
    By argomch in forum G-Code Programing
    Last Post: 09-24-2007, 12:22 PM
  5. Moving to absolutes
    By Chris Baird in forum Rhino 3D
    Last Post: 06-14-2006, 09:11 PM
