603,900 active members*
3,152 visitors online*
    Mar 2007
    5
    Problem with G02 en Plane X-Z with Mach3
    Hello,
    I have a problem with G02 code in XZ plane, with the last version of Mach3.
    This code should generate two semi-circle that form a circle, but the G02 do the same that G03:
    G49 G40 G80 G50 G61 G90
    G54
    G92.1
    G21 (mm)
    S1000
    (Set XZ Plane)
    G18
    G01 X50
    (First ARC G02)
    G01 z-14.500000
    (This is the error
    G02 X50 z-20.500000 I0 k-3.000000
    (if i would use G03 instead G02, math3 will produce the same job!! )
    (Second Arc G03)
    G01 X50
    G01 z-14.500000
    G03 X50 z-20.500000 I0 k-3.000000
    Note: The code is only to show the problem. I think there is but and the G02 is not woking in XZ Plane:
    The exact same code works fine in Mach2.
    The same example, but in XY Plane, works fine in Mach3.
    The problem ocurrs only wih G02 with G18.
    Any ideas?
    Thanks in advance!
    Mariano
    Mar 2003
    35494
    Either send this to Art or post in on the Yahoo group.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Problem with Mach3
    By SCOTTY76SA in forum SheetCam
    Last Post: 05-27-2007, 02:34 PM
  2. problem with my z axis on mach3
    By thesaent14 in forum Machines running Mach Software
    Last Post: 04-06-2007, 11:28 PM
  3. Mach3 Mill Pausing Problem
    By Lionclaw in forum Mach Mill
    Last Post: 11-14-2005, 07:05 PM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
