603,870 active members*
3,039 visitors online*
Results 1 to 7 of 7
    Jan 2004
    187
    proceedure upload heidenhain parameters
    Hello,
    can anyone instruct me in laymans terms how to upload and download the machine parameters on a Heidenhain 151 bridgeport series 11
    I can upload and download with nc programs using nclite.
    does anyone know the settings for Heidenhain Remo DNC Prog.
    thanks
    Brian
    BR
    Jan 2005
    1121
    It is very similar to programs
    mod
    code number
    95148
    <EXT>
    Jan 2004
    187
    thanks Gus,
    had to load parameters by hand. wont upload but downloads no probs.
    not the DNC program or the cable as they work with my Heidenhain 155 on a Beaver mill
    set at buadrate 2400 and EXT. I just bought the Bridgeport Friday past so it could be a parameter thats stopping it from uploading programs. any ideas on this
    Brian
    BR
    Jan 2005
    1121
    re
    It is probably an ascii issue. It may be appending an extra line feed or something at the end of lines. See if your program has ascii setting somewhere, or try using tncremote tncserver, which should set them the right way
    Jan 2004
    187
    Gus,
    tried tncRemote which goes to "stopped" as soon as I try to upload. maybe I dont have tncremote set up correctly.I am sure it is a parameter somewhere. I typed in a small prog.
    and it downloaded onto the pc which in turn uploaded and downloaded onto the other 2 machines with Heidenhain controls no problem using Nclite.I also downloaded the parameters thanks for the gen on that one.
    BR
    Jan 2005
    1121
    re
    my 310 was giving me crap yesterday, so I went back to hyperterminal
    7 bits, 1 stop bit, even parity, no flow control 2400 baud is always dependable. the 310 can do 19200 but the older controls may not go that fast
    there is also a ascii section and sometimes linefeeds can be an issue
    Jan 2004
    187
    Thanks I'll give it a try Saturday and check MP's
    71,218,219,220,221,222,223,224,
    BR
  1. can anyone help with heidenhain 2500 control parameters?
    By greg b in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2025, 09:51 PM
  2. Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
    By jeromir in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2018, 10:40 AM
  3. Heidenhain 2500 parameters
    By Daninwyoming in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2018, 07:38 PM
  4. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2014, 08:11 AM
  5. Machine parameters Heidenhain
    By praest in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2013, 02:54 PM
