587,999 active members*
2,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Recommendation for Lathe Selection
Results 1 to 7 of 7
    Sep 2006
    135
    Question Recommendation for Lathe Selection
    Thinking about converting a smaller lathe (in the 9x20 size) to CNC. I have an old Clausing 1300 but would like to keep it as a manual second lathe. Have read about pros/cons of one's from HF (mostly con) and seek advice on which lathe would most recommend for project. My experience with CNC is conversion of RF-31 mill/drill using servos and Mach3. Any input appreciated.
    Feb 2008
    180
    I just bought a enco 9x20 lathe to use for just a grooving lathe got it home and was pretty surprised how nice it is. It works great I did put it to the test and put a six inch round piece of aluminum in it and took .03 off the outside and the lathe did it. I was surprised ut it did it with a nice finish so I myself underestimated these small lathes. It has a little play in the handles but am sure it could be delt with if needed. Enco makes a good little lathe.
    Dec 2003
    24220
    I am just finishing the conversion of a 9x30 Lathemaster for my son, they are built pretty good for a R.O.C. machine.
    Al.
    Albert E.
    Mar 2008
    3655
    This one is a good candidate:
    http://grizzly.com/products/10-x-22-...al-Lathe/G0602
    CR.
    Sep 2006
    135
    Thanks for the replies. I'll take a look at each as I do my research. I'm also reading the 9x20yahoogroup. Thanks again.
    Apr 2005
    1778
    I have a 9x20 that I have started converting to cnc ( don't have the spindle encoder done yet), but it is producing products. However, if I were to buy a new small machine today I would definitely choose the Grizzly 10x22 over the 9x20.
    I also have a HF12x36 and I often find myself choosing to run a job on the 9x20 rather than the 12x36. I actually get a better finish on the parts cut with the 9x20 than the 12x36. But it took several years before I got the 9x20 tuned to where that was true. I was really reluctant to mess with the spindle, but once I fixed the preload on the spindle bearings the difference in the cuts was like night and day. The 12x36 is still factory stock and I think I could tune it up better too, if I had the time.
    Good luck,
    Alan
    Jan 2006
    204
    Link to bob's machine and a bunch of other stuff too
    http://www.cnccookbook.com/CCLatheCNCHome.htm
    archie =) =) =)
  1. CAD CAM recommendation
    By lipolad in forum Uncategorised CAM Discussion
    Last Post: 03-06-2008, 05:17 PM
  2. Cam Recommendation
    By dgoddard in forum Uncategorised CAM Discussion
    Last Post: 06-15-2007, 02:38 PM
  3. CAD/CAM recommendation
    By split63 in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 11:59 PM
  4. Recommendation Please
    By SPEEDRE in forum Autodesk
    Last Post: 02-13-2007, 12:33 AM
  5. lathe recommendation
    By marty7001 in forum Uncategorised MetalWorking Machines
    Last Post: 04-28-2006, 05:43 AM
