603,836 active members*
3,169 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > replacing ball bearings INA linear rails
    Feb 2007
    54
    I have some used INA linear bearing KWSE 25....the block kind, that ride on a profiled rail.
    Anybody familiar with replacing the ball bearings inside?
    Mar 2010
    Not worth it
    It's not worth trying. The carriages can be replaced for $55 ea and the rail for $95/meter. Your in this deep, do it right.
    Mar 2010
    11
    linear bearings are just like radial bearings.
    do you replace only balls in radial bearings? no you wouldn't because if balls are worn out, raceway where balls run will be worn out also.
    just like radial bearing, linear bearings have inner and outer race. outer race is the block, and inner race is the rail/shaft.
    so if block is worn, most likely the rail is worn too, or will soon. its a good idea to change both because running good block on worn rail is not only give u unsmooth motion, it will worn out the block quick also.
    changing balls in the block is not easy because you don't know what size ball is in there. and size here means micron increments of say 1/8" ball to have proper fit/clearance when assembled. heavy duty blocks have multiple ball circulations and each circulation may have different increments of balls.
  1. Glacern Supported Linear Rails & Bearings
    By Glacern in forum Linear and Rotary Motion
    Last Post: 02-12-2010, 07:35 PM
  2. Intermittently Supported Linear Ball Bushing Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-13-2009, 05:57 AM
  3. Linear Rails and Bearings
    By Robyn in forum News Announcements
    Last Post: 08-30-2006, 04:10 PM
  4. Linear Rails/guides and Bearings - What size is best?
    By Shawnusa in forum Linear and Rotary Motion
    Last Post: 10-29-2005, 04:51 PM
  5. Linear rails and bearings- overkill?
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 01-30-2004, 10:43 AM
