603,780 active members*
2,323 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo vs Stepper torque ratings
    Sep 2011
    474
    I recently replaced a 425oz/in stepper with a 90oz/in brushless servo. The servo had much more torque than the stepper did on the same rig even though it was rated far below the stepper's output. Why is this? Why is the servo rated at less than 1/4 the torque overpowering the stepper motor?
    Cheers and thanks in advance,
    SD
    Aug 2009
    653
    Re: Servo vs Stepper torque ratings
    I believe it's because the servo basically has 90 all the time and the servo has 425 when stopped (and generally you don't care) and then goes down based on speed.
    So as a machine speeds up, the servo becomes the more powerful motor torque wise.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Mar 2003
    35494
    The servo probably has 250oz of peak torque, usually available any any rpm.
    The steppers rpm falls off the faster it spins, and depending on the drive and voltage, may have less than 100oz of torque when you get to 500-800 rpm.
    So, at 1000 rpm, the servo can easily have 3x more power.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. don't know servo ratings required for diy mill
    By jasminder in forum Servo Motors / Drives
    Last Post: 11-27-2011, 08:51 PM
  2. stepper ratings
    By kool-lites in forum Stepper Motors / Drives
    Last Post: 12-20-2010, 11:01 PM
  3. Keling stepper ratings
    By MechanoMan in forum Stepper Motors / Drives
    Last Post: 04-12-2009, 03:20 PM
  4. calculating Servo Motor ratings
    By OwenL in forum Benchtop Machines
    Last Post: 03-17-2006, 06:27 PM
  5. Stepper motor ratings
    By thomasholley in forum Stepper Motors / Drives
    Last Post: 07-08-2004, 04:45 PM
