i am looking for a booster seat for my kid. Anyone got anything like that? Thanks
Necessity is the mother of all invention (unknown)
My club home page www.lhmac.org
Without going through 530 pages, and although there is some cool stuff you guys are sharing, and I will use, I am looking for 1911 grip DXF file if there are any. Mine has some very nice plastic grips and I have some tiger maple that is screaming my name. Thanks.
here is the short list
hope this helps
Attachments - CNCzone.com-The Largest Machinist Community on the net!
ghostlx
http://www.pure-teck.com/home.html
Hey everyone,
I've had another member bring up a good point that I really didn't think about.
Anytime we upload files it would be a good idea to label the file "router" or "plasma".
I know I'm guilty as all get out, about not adding a simple label.
All the plasma guys/gals know what I'm talking about, from parts falling out.
So, I'll start adding the label to any future files I post, hope it helps.
Free DXF - vectorink.com
Sorry for the delayed answer guy's I've been gone for awhile. Tweakie it is a polished high brass shell base. Switcher the base is a piece of scrap aluminum we had laying around. Hence the holes in it.
Ferny.
Can anyone help with this Farmall Tractor Emblem??
Here is a picture and a dxf file.
I would like the border and letters to be islands and standout.
A 3d file for a 1/8 bit would be good.
Any help would be appreciated.
Just a couple of ? ? ? ?
How big do you want the emblem to be. It seems to be only about 3/8" tall, is that right? ?
Also do you have a larger pic? The one you posted is very small, hard to convert it.
Larry![]()
Sorry for the small emblem picture. I'll try to find a bigger one.
The actual emblem is 1.5 in tall and 10.5 in long.
The letters are .75 in tall.
I found a larger picture of the emblem.
I apprciate your help.
I took a few liberties with your request to make it come out where it looked right to me. You didn’t give a depth for the pockets, so I made them .100", and the material thickness of .250". These can both be changed if they don’t work for you. As for using an 1.8" end mill, I couldn’t make that work on such a full part, BUT a 3/32" works well. I am including both the NC program and the DXF, so that you can change things if you want. If you run the program as posted, make sure that the G and M codes in the program match what your machine uses. I use a fixture offset of G54, which is the lower left of your material. Both X and Y are + from there. Top of stock is Z0, and I did not cut that. Stock size is 1.92" X 10.8" minimum. The part should come out at 1.86" X 10.73" .
I hope this helps you out with your project.
Larry
P.S. Watch your feeds and speeds, I just went generic as you didn’t list the material.![]()
P.P.S. change the extention from TXT to NC, or what ever your machine needs, OK?
Many thanks Larry,
You can see from this information that you have a good understanding of what is needed, especially for a newbie.
I appreciate your assistance and help.
Does anyone have a dxf of a sunflower that would work for cutting out on a laser. don't care if i had to make it a two peace.
thanks
hi i am new to this site, and from doing a basic seach i found alot of good programs for what i think is laser or mill. i have plasma and was wondering if anyone has a dxf or dwg of the dirtbike i have seen on here, and also does anyone have a file for a gun?
does anyone know of a way to convert jpegs bmps or tiffs or any type of picture into a dxf? a free way preferably... i have solidworks on my laptop, but dont think there is a converter?
Ryke,
Hope this works for your project,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Bwooten,
A lot of the fellows are using Inkscape
Inkscape. Draw Freely.
Check it out, its free.
Jeff...
Thanks, I d/l the program. now just need some help getting started... has anyone used inkscape. also i burned a seahorse this morning, it is one of the "puzzle" ones that you have to put together, and i was wondering if anyone has a picture of one put together?
I've been doing this for many years now, and have made many signs of this type. I'm glad that I could help with your project. Being retired now makes it easer to find the time to help others and perhaps teach the process behind making these types of projects. I still have a CNC and run it every week making Shadow Art pieces for my hobby/business.
If ever I can be of assistance, please feel free to ask. I know that there are many on this board that will be glad to help out with most any request.
Larry
