588,130 active members*
5,389 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 421 of 587 321371411419420421422423431471521
Results 8,401 to 8,420 of 11734
  1. #8401
    Feb 2012
    some one have a finger pointing sign?
    Take your pick.
    entry exit signs - Google Search
  2. #8402
    Dec 2011
    11
    JPG to DXF please!!!
    Attached Thumbnails Attached Thumbnails f090a484cffc.jpg   6cb6b066d44e.jpg   2dcff046d3a1.jpg   2b4e31bbeb63.jpg
  3. #8403
    Dec 2009
    19
    Browning
    Could someone convert this file to DXF for me?
  4. #8404
    Nov 2010
    schurabufu,
    I tried double back tape and it was ok...not great. How to do you all hold down small pieces. Can you give me some suggestions on bit speed, feed, etc. When you are just cutting out outlines can't you just use a smaller bit like 1/8" even if the board is thicker?
    Any help would be great as I really want to cut these things out. I only tried once and can use some help.
    Thanks- you guys are great!!
  5. #8405
    Nov 2007
    980
    Quote Originally Posted by 1462danny View Post
    Here ya go......
    Dave
    Attached Files Attached Files
    Dave->..
  6. #8406
    Dec 2009
    19
    Sweet, Thanks for the file
  7. #8407
    Feb 2007
    4553
    Quote Originally Posted by schurabufu View Post
    Schurabufu,
    Hope these work for your project they may need a little clean up yet.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  8. #8408
    Dec 2010
    92
    SMALL PIECES
    I am currently carving the Paradise Box by VCarve Pro out of MDF 1/2 inch thick board.
    I am using double sided tape, two pieces thick (about 1/8 inch thick total)
    On a board 12 inches by 5 inches I anchor the board at 8 points (four corners the middle and one each in the centre of the square that is formed)
    On a 14 inch square board I would use about ten pieces of tape, the double sided tape is the thick tape DO NOT use the thin stuff. The more pieces of tape you use the less movement there will be, experiment. Obviously MDF is a softer timber and a very sharp toolbit helps, as yet I have not tried harder timber.
    Regards
    Eric
  9. #8409
    Nov 2010
    3d Yoga or Lotus Position
    Does anyone have a yoga related or woman in a lotus position in 3d? I have Cut3d so could use an .stl file.
    Thanks!!
  10. #8410
    May 2008
    16
    did you ever find anything on the Lombardi trophy? I'm tasked with something very similar to what you were talking about...
  11. #8411
    Dec 2011
    11
    thank you!!!
  12. #8412
    Dec 2005
    17
    Converting a pdf to a engraving file
    After messing about with this project for a goodly time now I sure could use some help with what I'm trying to do. I volunteered to make some plaques for a club rifle shoot and while the text is easy to do I cannot convert the symbol of the club to insert into the plaques.
    The .pdf file attached contains two pages of junk to my needs and the symbol I'm needing is in the upper right corner of the page and it says Capitol City Rifle and Pistol Club.
    Would someone knowelable than myself see it's possible to get this to a file I can use for my plaques. I'm starting to get desperate now as the time closes in!!
    Thanks,
    Lee
  13. #8413
    Oct 2008
    406
    See if this will work for you.
    Bob
    "Bad decisions make good stories."
  14. #8414
    Dec 2005
    17
    Thanks Bob,
    At last I can see the image and start working on it now in Vcarve pro. I have an issue of of open vectors and duplicate vectors to deal with. Something I have been able to overcome in the past so the cut file is missing some of the detail but now hopefully with the manual and searching I can get it all connected together and working.
    What process did you use to get it to this state?
    I am just really enjoying using my cnc router and have been able to do some relatively simple tasks so far but each I succeed with this I'm learning. With your and others help it's made the learning curve a little shorter and in this case I really needed to get moving on this project.
    Thanks again,
    Lee
  15. #8415
    Oct 2010
    Love this thread,thanks everyone for your contributions.
  16. #8416
    Oct 2008
    406
    Lee,
    That was just a quick vector conversion using CorelDraw and exporting it as a DXF.
    Bob
  17. #8417
    Oct 2008
    406
    Quote Originally Posted by cruisor View Post
    I just did a quick bitmap-to-vector conversion using CorelDraw then exported the vector as a DXF.
    Bob
  18. #8418
    Dec 2005
    17
    Thanks for the info on the file. I've managed to get the file to the generate gcode state but found that it was way to busy to engrave, to many tiny lines. I cleaned it a bit more and will give it a try again tomorrow. What a learning curve this has!!
    Regards,
    Lee
  19. #8419
    Oct 2010
    Here is a another one you can try out to see if you can use.
    Good luck.
    Very good trace bobsch, just wondering, when you save it, do you save it as "lines and arcs" or "polylines" ?
    CNC 6040 Router Engraver
    Mack 3
  20. #8420
    Oct 2008
    406
    Quote Originally Posted by space67 View Post
    Good luck.
    Unfortunately Draw doesn't give you an option, except for text. Draw isn't perfect, but it's what I've got.
    Bob
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
