603,311 active members*
2,145 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask
IndustryArena Forum: Shopmaster/Shoptask
Page 3 of 31 1234513
Threads 41 to 60 of 601
Discuss Shopmaster/Shoptask machinery here!
  1. Mill Turn 5C chuck
    Started by jdub63, 12-07-2019 04:45 PM
    02-25-2020, 06:40 AM Go to last post
  2. Hello! 1994 Shoptask XMTC - modded
    Started by SupraRich, 12-30-2018 12:14 AM
    cnc, shoptask, spindle, tormach, vfd
    12-25-2019, 02:43 AM Go to last post
  3. Squaring my Y axis to the X axis
    Started by Tonkabot, 10-25-2018 09:20 PM
    degrees, pivot, point, spindle, square
    12-11-2019, 06:06 PM Go to last post
  4. Threading on a Patriot Shopmaster
    Started by Shrimp, 02-26-2019 12:18 AM
    2 Pages
    1 2
    11-18-2019, 05:31 PM Go to last post
  5. Shoptask 2000 modified
    Started by LtDan, 11-28-2016 03:20 PM
    2 Pages
    1 2
    06-28-2019, 08:05 AM Go to last post
  6. Tri Power Frying motherboards
    Started by aballworth, 10-13-2018 06:19 PM
    05-03-2019, 04:55 PM Go to last post
  7. retrofit Z axis, shoptask
    Started by CAD226B, 03-03-2017 04:56 AM
    02-27-2019, 01:51 PM Go to last post
  8. GSK cnc cCOntrol 980TDC Threeding cycle problem
    Started by RanaAli, 02-27-2019 12:08 PM
    cnc, cycle, machine, mazak, working
    02-27-2019, 12:08 PM Go to last post
  9. Stabilize z axis spindle arm.
    Started by CAD226B, 02-24-2019 05:50 PM
    02-24-2019, 05:50 PM Go to last post
  10. How capable are these machines?
    Started by cnczoner, 01-29-2019 07:39 PM
    cnc, machine, make, mill, tormach
    02-18-2019, 06:58 PM Go to last post
  11. Shopmaster turnado lathe
    Started by SB5C, 11-29-2018 04:34 PM
    cnc, lathe, mach3, machine, machinist
    01-31-2019, 12:32 AM Go to last post
  12. Rust prevention for the winter
    Started by CrispyD, 10-01-2018 01:57 AM
    01-30-2019, 06:17 PM Go to last post
  13. Shopmaster Mill Turn 2017
    Started by Goodlett, 01-01-2018 07:20 PM
    01-30-2019, 07:26 AM Go to last post
  14. Patriot Model
    Started by jlmccuan, 01-29-2019 06:27 PM
    cam, great, model, patriot, step
    01-29-2019, 06:27 PM Go to last post
    11-08-2018, 05:34 AM Go to last post
  15. AC servo conversion on CNC Patriot VFD machine
    Started by mackeym, 09-22-2015 12:09 AM
    2 Pages
    1 2
    10-09-2018, 07:57 PM Go to last post
    10-06-2018, 06:07 PM Go to last post
  16. 3d Printed Threading Gears
    Started by aballworth, 10-03-2018 06:20 PM
    gears, great, printer, threading, work
    10-03-2018, 06:20 PM Go to last post
  17. 2007 Tri-Power not repeating
    Started by jsmithwe, 08-09-2018 08:21 PM
    axis, factory, installed, machines, machinist
    10-03-2018, 06:05 PM Go to last post
  18. UPGRADING THE MILL TURN SPINDLE FOR HIGH SPEED USE
    Started by JTJT, 09-16-2016 05:56 PM
    bearings, motor, pulley, speeds, spindle
    09-12-2018, 03:37 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
