603,947 active members*
3,087 visitors online*
Results 1 to 20 of 61
Threaded View
beamsjr 8020 CNC Build 01-15-2011, 07:43 PM
DIYaholic Inquiring Minds want to Know? 01-15-2011, 08:07 PM
beamsjr Hi Randy, The cutting... 01-15-2011, 09:12 PM
RicknBeachcrest Here is the link to the... 01-15-2011, 09:47 PM
beamsjr My controller 01-15-2011, 09:48 PM
DIYaholic beamsjr, Cool vid of your... 01-15-2011, 10:37 PM
beamsjr I went ahead and put an order... 01-16-2011, 01:44 PM
DonFrambach I see you're going to use... 01-17-2011, 10:28 PM
beamsjr Are the resistors in the... 01-17-2011, 10:59 PM
DonFrambach Maybe there's no problem. ... 01-18-2011, 04:31 AM
beamsjr Z axis done 01-22-2011, 01:39 AM
beamsjr A little more work done. 01-28-2011, 02:12 AM
beamsjr I am starting to get worried... 01-17-2011, 08:35 PM
Phife I would rather over design a... 01-17-2011, 09:29 PM
ahren Joe, Looking really good! ... 01-29-2011, 12:43 AM
beamsjr Thanks for the tip Ahren,... 01-31-2011, 02:18 PM
DonFrambach If you haven't figured it out... 02-01-2011, 04:45 AM
beamsjr I figured out that I had the... 02-01-2011, 04:07 PM
RedskinsJBS Looking like progress! I... 02-08-2011, 03:05 PM
beamsjr Yep, the are 3/4" 5/16-18... 02-08-2011, 03:50 PM
RedskinsJBS Great! Thanks a bunch. I... 02-08-2011, 04:24 PM
beamsjr I am going to pull them off... 02-08-2011, 04:37 PM
RedskinsJBS What grade bolts did you use?... 02-08-2011, 09:05 PM
beamsjr The ones I used were... 02-08-2011, 09:25 PM
beamsjr Started painting the rails... 02-10-2011, 02:19 AM
nuplowboy Will the bearings actually... 02-10-2011, 03:42 AM
RedskinsJBS We could argue all day about... 02-22-2011, 02:46 PM
beamsjr It is registered, I also... 02-25-2011, 10:10 PM
LeeWay You can run Mach 3 in 7 as... 02-25-2011, 11:10 PM
    May 2009
    56
    8020 CNC Build
    Hi, I have been reading and learning over the last year (On and Off) and I am finally beginning my build. This will actually be my second build, My first was from MDF and I was less than happy with the results.
    I have decided to build my machine from 8020 using cncrouterparts rack and pinion setup. I started getting the 8020 from ebay, and just recieved my 3x3 pieces with more arriving on tuesday. I just noticed that the 1.5x1.5 pieces were the light vesion and not heavy, Not sure what Im going to do about that, I will have to see what it is like when I get it in.
    I am including a picture of my planed setup, please let me know what you think. I am also planing on doing some 45's in the corners to stiffen it up.
    I am excited about this build and will share my experience as much as I can.
    Attached Thumbnails Attached Thumbnails Screen shot 2011-01-15 at 1.30.59 PM.png
  1. 8020 BBR Router Build
    By ddbuster in forum DIY CNC Router Table Machines
    Last Post: 10-15-2017, 12:16 AM
  2. Yet Another 8020 CNC Build
    By jsantos in forum Open Source CNC Machine Designs
    Last Post: 04-29-2012, 10:14 PM
  3. 8020 build 3x5
    By sieg01 in forum CNC Wood Router Project Log
    Last Post: 03-17-2009, 10:08 PM
  4. Another 8020 build
    By Micky15044 in forum Open Source CNC Machine Designs
    Last Post: 08-17-2008, 03:45 AM
  5. 8020 Aluminum Build
    By klick0 in forum CNC Wood Router Project Log
    Last Post: 07-09-2008, 03:32 PM
