603,358 active members*
3,073 visitors online*
Page 1 of 11 123
Results 1 to 20 of 204
    Dec 2009
    528
    Yet Another 8020 CNC Build
    Hi All,
    I've been lurking here for almost a month now trying to learn everything I can about building a CNC router. I'm a newbie and know very little about building a CNC. Everything I know about CNCs came from a couple of books, the threads in this form and from Ahren of cncrouterparts.com. Ahren has been very helpful in answering questions I have.
    So now I'm ready to start building one. So here goes:
    - 8' x 5' built mainly from 8020 aluminum
    - Carriages & R&P from Ahren
    - Rack from Moore Gear
    - Rack clamps from Ahren
    - Cold-rolled steel from McMaster
    - GeckoDrive G540
    - 380 oz-in from Ahren and Keling
    - Power supply from Keling
    - 8-inch z-axis from K2CNC
    - Mach3 software
    - Haven't decided on cad/cam yet
    I've attached pictures of the plan. I tried to upload a sketchup file (2.3M) but I keep getting upload errors.
    1.jpg - The whole thing.
    2.jpg - I'm recycling the support and legs from my existing workbench. The CNC will also double as my workbench.
    3.jpg - Frame. The overall frame will be 3030. 1515s will be ued to support the table top (mdf).
    4.jpg - X-Axis Drive - Will use R&P from Ahren. Driven on both sides.
    5.jpg - Gantry - The verticals supports are 1530. All the rest are 3030.
    6.jpg - Y-Axis Drive. Will use R&P from Ahren. Not sure if I really need the carriages at the bottom.
    7.jpg - The z-axis will be mounted on the stock aluminum shown.
    8.jpg - Closer view of the overall CNC.
    Now, if only the weather will cooperate and warm up a bit so I can start. :-(
    Comments and suggestions are solicited and very welcome!
    Mar 2003
    35494
    You'll need to support the sides somehow.
    And try zipping the Sketchup file and upload that.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2009
    528
    I was afraid of that. Would putting support in the middle of the sides suffice?
    I did zip the file. It was a 6.8M file and zipped down to just over 2M. I got the error (failed to upload) when I tried uploading the zip file.
    Thanks!
    Feb 2004
    1086
    Joe,
    Looks like a really stout machine, although I'm not sure you need all of the framework you have constructed. I personally would use a piece of 3060, a 7" wide piece of steel on the front of it, and the R&P running along the top (turned sideways). This should be easier to construct and just as strong if not stronger. Plus, this will only require two extended carriages on the gantry.
    Ahren
    www.cncrouterparts.com
    Dec 2009
    528
    Hi Ahren,
    Is a 7" cold-rolled steel available? I checked with McMaster and Grainger and it looks like the widest they have is 6". But based on your suggestion, can I turn the rails vertical using 2 4" and 2 3030? Or would not pose a problem with possible unevenness?
    Feb 2004
    1086
    Joe,
    McMaster and Grainger have crummy selections on raw materials. I would personally order from an actual metal supplier. One suggestion is speedy metals (speedymetals.com). Here's the page with 7" CRS:
    http://www.speedymetals.com/c-8213-1018.aspx?pagenum=4
    Your other route might work too. Unevenness isn't really a problem. The only thing is you want a 1/2" overhang from the steel past the aluminum to set the spacing for the R&P correctly.
    Ahren
    Dec 2009
    528
    Hi Ahren,
    Thanks for the link to speedymetal.
    Revised gantry picture is attached. I'll look at using a 7" CRS but will use 2 3030 instead of a 3060 as I have the 3030s but not the 3060s. :-)
    Couple of questions on using a vertical rail:
    1. The racks will now be on top. Would that cause a problem with wood dust?
    2. The two carriages are now held together by just the z-axis mounting plate. Will that be stable enough?
    Feb 2004
    1086
    Looking good -- that's what I had in mind. If you are going with two pieces of 3030, however, I would get 8" wide steel and put a space between them. The faces on the extrusion are not exactly flat (they get flat once you fasten things onto them), and you need the 1/2" clearance on either side, and things are pretty tight at that. It would stink for a small twist in the extrusion to keep everything from going together nicely, so it will be nice to have a little adjustability.
    As for the R&P on top, the dust shouldn't be a big problem, since the teeth of the rack are still oriented sideways.
    For the Z axis, it will be stiff enough if:
    1) You use a thicker plate
    OR
    2) You make it out of steel
    Or both. This is going to be one nice beefy machine!
    Ahren
    Dec 2009
    528
    Hear you on using an 8" rail. Didn't think of the possible problems with 2 3030s.
    So how thick a steel plate should I use for the z-axis? If I want to go aluminum, how thick should it be?
    BTW, the motor, R&P and rack clamps arrived today priority mail. I didn't know priority mail delivered saturday. :-)
    And I love that the motor already has the DB-9 with the current resistor set installed. Thanks!
    Apr 2003
    312
    The redesign of your gantry looks nice. It also eliminates a number of those expensive corner brackets... not to mention the hardware to attach them! Certainly a stiffness increase over what your first design had.
    It's inspiring to see these new R&P designs unfold. The previous limitations of table size have been virtually eliminated without the attendant logarithmic increase in price one would see with other linear rail/ballscrew designs.
    Looking good!
    Senna
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Dec 2009
    528
    Thanks Senna.
    The R&P solution does look much lower, cost-wise, than other solutions. Hopefully, it will work just as well. :-)
    I've taken apart my workbench and started building the CNC frame on top of it.
    Unfortunately, it will be below 0 in the next couple of days, so no working in the garage for me. :=(
    Dec 2009
    528
    The weather is warm enough now for me to work on the garage. Okay, it's still only 18F, but with an infrared heater and dressing up looking like a Michelin man, I can keep warm enough. :-)
    The pictures show what I've done so far.
    Ahren - How big are the holes that I should be drilling on the CRS rails? I was thinking of making them 3/8" instead of 5/16" to allow for adjustments I have to make them parallel to each other. Is 3/8" too big or too small?
    Old workbench.jpg - This is what my workbench looked like before.
    CNC Frame 1.jpg - I disassembled the workbench and lengthened its rails to 6 feet. The basic frame of the CNC is now put together. The 8020 sitting on top is not part of the frame. I was using that to make the rails of the frame parallel.
    CNC Frame 2.jpg - The frame raised so I can tightened the bolts underneath.
    Attached Thumbnails Attached Thumbnails Old workbench.jpg   CNC Frame 1.jpg   CNC Frame 2.jpg
    Feb 2004
    1086
    Looking good! In answer to your question, 3/8" should be fine, and it is a good idea to go a little oversized on the holes. Obviously, it's still good to doo what you can to get them in the right place -- it's helpful to have a drill press and a block to hold a consistent distance off the side of the rail. If you don't have this, a hand drill, measuring square, and a center punch are the next best thing.
    Best regards,
    Ahren
    Dec 2009
    528
    Ahren,
    Thanks. I do have a drill press with a good guide so I should be able to drill the holes at a consistent distance from the edge.
    Got the racks from Moore Gear installed on both x-axis. We'll see how good they are. Have you had a chance to test them?
    Your rack clamps are god-sent! They made it very easy to install the racks. The clamps also forces the racks to straighten. Don't think drilling holes in the rack and bolting them would have done that! Will post pictures of them later.
    Also received the db-9 cables today. Looks very well built and the red color will sure call attention to these cables. LOL.
    Somehow, though, I have to figure out what I'm going to do with cables that I have to run to the y- and z-axis. These 12 foot cables will cover one x-axis from one end to the other, but won't be long enough to reach the motors on the other x- and y- and z-axis. That was why I was asking if you've got shorter cables. Or maybe cables longer than 12 feet.
    Now to drilling lots of holes. :-)
    Feb 2004
    1086
    Joe,
    Glad things are working out. I do like the rack clamps too just for ease of installation. Yet another thing I'm scrambling to get back in stock. More pictures would be great -- the ones I have had time to take don't really do the system justice.
    As for the cables, you can double them up if you need a longer length. I am planning on getting some 20 footers in stock, but it will be a little while. The red color on the bearings in cables is my one nod to machine fashion, since it only costs a few extra pennies. I figure if people are going to invest the money in a machine, it's worth it to make it look bad-ass .
    I've seen the racks from Moore, but haven't actually run a system on them yet. They appeared to be high-quality from what I saw -- let me know what you think once you get your beast up and running.
    Good luck with the hole drilling!
    Ahren
    Dec 2009
    528
    Ahren
    How far apart should I space the bolts for the rails? What's the ideal and what's the farthest I can get away with?
    Looks like drilling holes on 1/4 CRS is very different from drilling into wood. Any suggestions on technique? I'm using cutting oil as lubricant but I'm not sure if I should apply it once or apply it multiple times as I'm drilling the hole? Am I supposed to peck or just punch it through? Or...
    So many things to learn ...
  17. #17
    Feb 2004
    1086
    Joe,
    I'd try to get holes every 8-9". The more the better -- it's hard to have too many. For steel, you want to run your drill on slower speeds to avoid burning your bit. It's probably easier to drill 1/4" holes first, and then clean them out with a 3/8" (the 3/8" should self-center on the previous hole). The 1/4" will go through easier, and should center better. You'll need a good bit of pressure, and back out regularly to clear the swarf. Cutting oil is nice to put in once you get a little bit of a pocket started so it can stay in the hole.
    Others on here might suggest specific tooling -- a TiN coated bit may stay sharper longer. Feel free to chime in folks. Good luck, and don't despair -- this should be the hardest part of the build.
    Ahren
  18. #18
    Dec 2009
    528
    Rack pictures
    Here are the images of the rack installation. If you're going to use R&P, I would strongly recommend using Ahren's rack clamps. Installation went very smoothly and quickly - well, except for one little problem on the second rack.
    rack 1.jpg - First rack installation. I've already installed four of the 6 clamps I was using. The rack for the other side is sitting on top.
    rack 2.jpg - A closer look of how the rack is installed with the clamps.
    rack 3.jpg - A much closer look of the clamp. I forced the rack up against the clamp to straighten the rack and the clamp also forces the rack against the extrusion. Nice, clean and very easy installation.
    rack 5.jpg - Underside view of the installation.
    rack 6.jpg - Oops. Have to cut the other rack. It was longer than the other one.
    Attached Thumbnails Attached Thumbnails Rack 1.jpg   rack 2.jpg   rack 4.jpg   rack 5.jpg
  19. #19
    Dec 2009
    528
    CRS - 1, Drill & Operator - 0
    Boy, never knew that drilling through steel is going to be so much harder. Broke a bit, got the bit stuck in the CRS, chuck falling out of the arbor, and smoke all over the place. Good thing I was trying this on a test piece. Sigh...
    But despite all that, I finally got the holes on the test piece, fitted it on the extrusion and, wonder of wonders, it fits!
    Never thought that one can get so elated in seeing a piece of steel fit nicely on top of an extrusion. :-)
    QUESTION: I think what I was doing wrong in all of this was I was feeding too fast. But even though I am now able to drill the holes with the bit not breaking or getting stuck, I'm still getting smoke. Is that because of the cutting oil burning? Or am I still feeding too fast?
  20. #20
    Apr 2007
    8082
    Quote Originally Posted by jsantos View Post
    Use a 135 degree split point drill bit. It is center cutting and needs much less down feed pressure to cut. A regular drill bit is not really center cutting and is why pre-drilling with a smaller drill helps the larger drill cut better. Slow your drilling speed down also. Use just enough rpm to not cause the drill to pull out blue or yellow chips. Too much rpm will dull the drill's cutting edges by removing the temper.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
Page 1 of 11 123
  1. 8020 BBR Router Build
    By ddbuster in forum DIY CNC Router Table Machines
    Last Post: 10-15-2017, 12:16 AM
  2. 8020 build 3x5
    By sieg01 in forum CNC Wood Router Project Log
    Last Post: 03-17-2009, 10:08 PM
  3. Another 8020 build
    By Micky15044 in forum Open Source CNC Machine Designs
    Last Post: 08-17-2008, 03:45 AM
  4. 8020 Aluminum Build
    By klick0 in forum CNC Wood Router Project Log
    Last Post: 07-09-2008, 03:32 PM
  5. First build - 8020 with servos or steppers
    By sandiegocadcam in forum DIY CNC Router Table Machines
    Last Post: 03-24-2008, 11:21 PM
