588,239 active members*
4,389 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > g540 / superpid / mach3
Results 1 to 2 of 2
    Sep 2009
    1856
    does anyone now what config to use for the superpid running mach3 through a g540
    can get spindle to turn on and off but cannot seem to change the speed of the spindle in mach 3 help please
    Sep 2009
    1856
    every thing is configed and wired properly it will do 5000rpm or 30000rpm only
    have set pully 4 to 5000 min 30000 max will try changeing to 5000rpm min 10000rpm max a see if it will do 5000 or 10000 if it does work will config pullys 5000min 6000max so on
  1. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-03-2012, 05:10 AM
  2. Setting up X and Y G540/Mach3
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:46 AM
  3. Help with Mach3 and missing steps G540
    By tristen0821 in forum DIY CNC Router Table Machines
    Last Post: 01-26-2011, 02:51 PM
  4. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2009, 12:09 AM
  5. G540 Mach3 XML File
    By CoAMarcus in forum Gecko Drives
    Last Post: 11-08-2008, 06:38 AM
