havent we all been using grease fittings since our first car in my case this is somthing i have to do on all my farm equipment and shop equipment'
ypu just squirt a little in untill it fills out a bit the grease packs in good and will stiffen a bit in extreme cold and melt in extreme heat 95 degrees farenhiet+ that is when i would watch it most
we have a scedule written on a board on a wall because with 30+ pieces of equipment it is easy to forget!!!
we check grease all new equipment as most assemblers in whatever countrie have probably NO knowledge of what the equipment they are prepareing does
much less what grease it needs
i cant imagine any of us would buy a new or used car and run it flat out without checking the oil
cabnet
