588,112 active members*
5,148 visitors online*
Thread: Hoss's G0704
Page 11 of 48 91011121321
Results 201 to 220 of 945
  1. #201
    Jun 2007
    3891
    Quote Originally Posted by HimyKabibble View Post
    I would bet that if you took the radial load rating of a ball bearing, an angular contact bearing with the same size balls would support roughly that same load, but applied at the bearings angle. A little simple trigonometry will let you resolve that into radial and axial component forces. This would at least give you a very closer approximation.
    Regards,
    Ray L.
    well, it isnt that simple i dont hink. cause a radial load is only loading 1/2 the balls at any given time with varying force. axial is loading all balls with the same force. it may be that an angular contact bearing can take more force axially than radially. if you look at a comparably sized thrust bearing, they take many times more force than the radial bearings.
    i think we'll leave this one to "let hoss test it"
    if it works with no issues for him, i think it would be fine. hes got a radial bearing in the x2 with a similar drawbar and that seems fine.
  2. #202
    Feb 2006
    7063
    The information is available on the SKF website:
    http://www.skf.com/portal/skf/home/p...newlink=1_3_13
    For deep groove bearings, axial load rating is typically 50% of the radial load rating, and for angular contact, it will be higher.
    Regards,
    Ray L.
  3. #203
    Quote Originally Posted by Deviant View Post
    How do you think using the quill for your tool change will effect the repeatability.
    Can't view youtube at work....
    So I'm assming that you..
    1. Unlock quill.
    2. Move the quill down.
    3. Flip up your MAD bar...
    4. Retract the quill which compressess the bevel washers and drops the tool.
    5. Move quill down and flip MAD out of the way.
    6. Retract quill and lock the quill in place.
    If this is the order of events, do you think that the tool offset will change much or do you expect the quill to return to the same location everytime.
    Keep up the good work.
    You got it right, just put in the next tool too.
    I'll make a video soon showing how it can be used as a manual ATC.
    Remove the rubber ring (#250) in the parts list.
    The quill will stop nice and flush with the bottom of the head for a "home" position.
    The DRO could also be used, I'll be using it for tool offsets as well.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #204
    Angular contact bearings support thrust loads or combinations of radial and thrust loading. They cannot accept radial loads only --a thrust load of sufficient magnitude must be present. An individual angular contact bearing can be thrust-loaded in only one direction; this load may be a working load or a preload.
    - Barden Precision Ball Bearings
    Seems to me that providing a static radial load rating for a bearing that can't accept radial loads on it's own would be pointless.
    I would say again that the static load rating for AC's is axial just like tapered rollers.
    Hoss
  5. #205
    Aug 2008
    74
    That's an amazingly simple and effective toolchanger. It makes the solution at Usovo seem like massive overkill and expense by comparison.
    It does surprise me that you can generate enough force to overcome the clamping pressure by hand. For some reason, I assumed that that amount of force was pretty significant... spring strengths measured in thousands of pounds, underengineered power drawbars bending under the force, etc etc.
  6. #206
    No massive force here, just about 750 lbs, good enough for "light" duty work,
    same as my X2 has been doing for the past 3 years.
    http://www.hossmachine.info/FAQ.html question # 16.
    I'll order some more bellevilles and try a 1500 lb test.
    I don't have enough to stack them (())(()) to get twice the force and the same deflection to open the collet.
    If I have enough a*s to do it, I'll probably snap one of the quill handles off.
    We'll give it a go anyway.
    Hoss
  7. #207
    May 2005
    2502
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Think of the advantages your new big bicep "guns" will give you with the fairer sex!
    BTW, if you want the "good" Kluber grease, you can get it directly from Kluber's online store:
    https://www.klubershop.com/search.aspx
    It's about $20 a tube, but you have to register (usual name and address questions). This is for Kluber Isoflex NBU-15, which is what you'll find on a lot of high end spindles. Why use it? Higher speed rating (850,000 dN) plus its formulated to shrug off way oil.
    Probably extravagant unless you're going for that little extra bit of spindle speed. 8K rpm on one of these?
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  8. #208
    Just ordered a tube of Isoflex NBU-15, $28.36 shipped. That's more than the bearings.
    That'll end any questions of what the spindle can run at, should be the right stuff.
    Get to take the spindle apart AGAIN.
    MscDirect has a sale today and tomorrow on Hertel tooling, 45% off.
    Picked up a few more 3/8 endmills, only $7 a piece.
    See too many newbies buying the chinese junk and then complain about
    crappy parts, crappy finishes and broken bits.
    Wait for the good stuff to go on sale, they do a lot at MSC, and get some quality endmills, you'll be better off.
    Sharp tools make milling fun not an ordeal like so many go thru.
    Don't try to learn using junk, you won't know if the problems you are having
    are your fault, the machines or in most cases, the shoddy bits.
    Just and old farts advice.
    Hoss
  9. #209
    Apr 2004
    88
    If you follow this link
    http://www.nsk.com/products/spb/angu...ndex.html#tab4
    and open the lubrication .pdf there is all kinds of good info on spindle bearing lubrication.
    The table for grease quantity shows 7007=.98 cc of grease
    7005= .52 cc
    An infant liquid medicine syringe is a great dispenser/aplicator.
    Pull out the plunger,squeeze a bunch of grease from the tube
    into the syring, then inject the surplus back into the tube.
    (no waste that stuff is expensive!)
    Now you can dispense the grease evenly onto the inner and outer
    races .
  10. #210
    Nov 2008
    103
    Not to nag Hoss (guess the "guns" just aren't big enough yet to hypnotize me) but please clean all the old grease out properly with solvents that dont leave residue. If you spent money on good grease no use breaking it down to liquid mush with kerosene or mineral oil residues (wd40). I'd be nice to see what it all can really do.
  11. #211
    Quote Originally Posted by steveg View Post
    7005= .52 cc
    races .
    Good idea, I have lots of syringes and needles.
    Hoss
  12. #212
    Quote Originally Posted by machinechick View Post
    Can do, what do you recommend? I have simple green.
    Hoss
  13. #213
    Jun 2007
    3891
    *hides the wd40 can next to his new wmd16v*
  14. #214
    May 2005
    2502
    Good catch on that sale Hoss!
    It's really a smokin' deal if you want a nice set of Hertel twist drills--about 1/2 price for USA made twist drills.
    Trying to decide if I need a nice set of cobalts...
    BW
  15. #215
    Nov 2008
    103
    degreasing solvents
    Hoss
    I live by a "Mom and Pop" hardware store and they have Carbon Tetrachloride in old metal "Sunnyside Chemical" containers, guess it's been on the shelf since the 1970's. That is what I've been using. I love it, cleans great, evaporates quickly and completely so you can keep working. I never have never seen it anywhere else and think it's probably been long banned by the EPA!
    In a previous post in this thread this subject was discussed and I believe Stereg suggested first degreasing with mineral spirits, then removing the mineral spirit residue with methanol, sounds good to me, and they sell that stuff everywhere they sell paint.
  16. #216
    Aug 2008
    962
    Didn't someone previously mention brake cleaner to clean up the mineral spirits? That would be easy to come by ..
    gd.marsh
  17. #217
    May 2005
    2502
    FWIW, these guys suggest filtered gasoline to clean precision spindle bearings before grease packing:
    http://www.gmnbt.com/spindlebearings_installation.htm
    Don't burn yourself up!
    Of course, since you have the Kluber uber-grease, you may want the Kluber uber-cleaning-procedure:
    http://www.klueber.com/PDF_Dokumente...EANING_ENG.pdf
    Brake Cleaner is on that list:
    http://www.berrymanproducts.com/Portals/0/1420.pdf
    Cheers,
    BW
  18. #218
    May 2008
    1185
    The generic carb(not B12 cemtool) cleaner is a better solvent most have zyline and Triple T. I have use it for may years to remove tar spot when carpet cleaning. The break cleaner is not strong enough to remove gar gum or tar.
  19. #219
    Lots of good advise, thanks gang.
    I'll see what I have, might already have spirits, carb and brake cleaners.
    Hoss
  20. #220
    Jan 2008
    30
    ... MscDirect has a sale today and tomorrow on Hertel tooling, 45% off.
    Hoss
    Hoss,
    Thanks for the heads up on that. I was overdue for getting a good selection of endmills to have on hand for all the projects. Now I am well stocked, and my wallet isn't nearly as light as it would have been.
    Regards,
    Raymond
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
