587,501 active members*
3,162 visitors online*
Page 7 of 43 5678917
Results 121 to 140 of 848
  1. #121
    Oct 2009
    838
    Re: David A's New 2x3 Bench Top CNC
    HuguesP and mactec54, thanks for your encouragements.
  2. #122
    Oct 2009
    838
    Now, the machine needs to be leveled,
    not only for actual cutting but also for
    the cutting coolant system to work.
    Poor a bit of colored water on the bed.
    Also a good test for any leakage:
    Attachment 414108
    You want the water to ever so slightly
    and evenly to collect along the line of
    the drain slots:
Name:	22B IMG_7630.jpg
  3. #123
    Oct 2009
    838
    The machine weighs about 330 pounds.
    Attachment 414114
    It is a bit tough to turn the 1" bolts of the
    feet with that weight on them. A car
    jack makes it easy to fine tune the level
    of the machine without hurting my back:
Name:	24 IMG_7627.jpg
  4. #124
    Sep 2005
    1740
    Looking forward to the first project!!
  5. #125
    Oct 2009
    838
    Hah, wmgeorge, me too, believe me.
    Still some ways to go though......
    I will need all the expertise I can get
    once I get to the electrical part.
  6. #126
    Oct 2009
    838
    Cutting coolant pump in action.
    It's got way more flow than I was thinking.
    Anybody has an idea for a simple flow restrictor
    for 3/8 OD tubing?
    Maybe need to put some flow restrictor in line:
    https://youtu.be/ZA0YPjmymPo
  7. #127
    Oct 2009
    838
    And here are the spouts discharging.
    I need to design better spouts though,
    splattering all over the tray. Needs short
    pieces of tubing instead of a slot:
    https://youtu.be/gHQY4D2CxuU
  8. #128
    Oct 2009
    838
    The cutting coolant system works better
    than I expected but needs a bit of fine
    tuning.
    restrictor for 3/8 OD tubing?
    Do these revisions ever end?
  9. #129
    Oct 2009
    838
    Move on to the next component.
    THE VACUUM SYSTEM:
    The table is made up of 1" HDPE strips:
    Attachment 414166
    The aluminum sheet bed has corresponding
    transfer holes for the vacuum system:
    Attachment 414168
    The HDPE has vacuum holes on top
    throughout on a 1-3/8 grid:
Name:	3B IMG_7612.jpg
  10. #130
    Sep 2005
    1740
    If your just needing to cut aluminum than a mister directly on the tool would work fine. Of you can flood coolant. In either case you need a add a small ball valve for control.
  11. #131
    Oct 2009
    838
    Close-up of the vacuum holes:
    Attachment 414172
    There are channels on the bottom of
    those HDPE strips, carrying the
    vacuum to each hole:
    Attachment 414174
Name:	6B IMG_6524.jpg
  12. #132
    Oct 2009
    838
    There is a simple manifold at the bottom
    of the machine bed, connecting all
    vacuum channels on top of the HDPE table:
    Attachment 414178
    Attachment 414180
    Ready for assembly to the bottom:
    Attachment 414182
  13. #133
    Oct 2009
    838
    Align the manifold to the bottom of
    the bed and tighten it from the top:
    Attachment 414184
    Manifold installed to the bottom:
    Attachment 414186
    Choose the size of your PVC fitting to
    match the size of your vacuum hose:
Name:	12 IMG_7134.jpg
  14. #134
    Oct 2009
    838
    Vacuum system finished.
    Of course, the PVC fitting can be rotated in any
    direction you want. I oriented it to the front:
    Attachment 414190
    Attachment 414192
  15. #135
    Oct 2009
    838
    Quote Originally Posted by wmgeorge View Post
    Thank you wmgeorge. I read somewhere
    that misting works great but flood coolant
    can actually produce a better finish.
    No idea if that's true. Will try out both.
  16. #136
    15362
    Quote Originally Posted by davida1234 View Post
    tuning.
    You don't need any flow restrictions the more flow/ pressure the better, for your drain yes you want to drain that down into the tank with a large tube
    Mactec54
  17. #137
    Oct 2009
    838
    Thanks mactec54, I need to play around with it a bit.
  18. #138
    Oct 2009
    838
    Machine is somewhat cleaned, ready
    for a test of the vacuum system.
    I will be using a 12 gallon, 5 peak HP
    shop vac to try out the vacuum:
Name:	15 IMG_7645.jpg
    The 1-3/4" hose end fits tightly over the
    vacuum adaptor with some sweet talk:
Name:	16 IMG_7639.jpg
  19. #139
    Oct 2009
    838
    Shop vac hose and adaptor hooked
    up to the vacuum system:
    Attachment 414270
    Later, there will be a single piece
    4MM or 6MM MDF cover over the
    table which I don't have at this moment.
    Here I am trying it out with a 13x18
    plastic pouch. Remaining holes are
    covered with sheets of paper:
Name:	18 IMG_7647.jpg
  20. #140
    Oct 2009
    838
    Here is the test.
    You need about 9-10 pounds of pull to make the pouch move.
    The single point pull with the scale makes the pouch
    crease up before letting go. A full width, even pull would
    probably show somewhat higher values:
    https://youtu.be/m4Y1mKaiFt0
  1. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  2. CNC bench lathe or other small bench lathes
    By Scootworks in forum Turning Machines
    Last Post: 08-20-2011, 06:36 AM
  3. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  4. David
    By [email protected] in forum Fanuc
    Last Post: 12-11-2009, 08:56 PM
