603,879 active members*
4,724 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > CSMIO/IP-S Ethernet Motion Controller (CNC)
    Exclamation CSMIO/IP-S Ethernet Motion Controller (CNC)
    CSMIO/IP-S Ethernet Motion Controller by CS-Lab Electronics (CNC)
    (Mach3)
    DETAILS:
    - PC connection via Ethernet.
    - 6 axis controller.
    - STEP frequency to 4MHz (differential outputs, very resistant to interference).
    - Extremely stable machine speed control, thanks to the FPGA and advanced control algorithms.
    - 32 digital inputs and 16 digital outputs (possibility to extend to 192 inputs / 96 outputs through additional modules).
    - 4 analog inputs / 2 analog outputs (0-10V).
    - All I/O are optically isolated, protected against short circuit, overheating, industry standard - 24V.
    - Up to 3 slave axis support, machine geometry correction.
    - Spindle inverter control through analog outputs.
    - An extension of functionality through additional CanOpen modules. Currently available modules:
    CSMIO-IO – module of 16 additional inputs and 8 outputs (24V, optical isolation, overload protection). Possible to connect 10 of these modules.
    CSMIO-JOG – MPG connection modules – smooth control of the machine motion, automatic switching between speed and position mode.
    Work is underway on the CSMIO-SCAN module - to operate the laser scanner.
    - Solid aluminium enclosure that discharge the heat very well and perfectly protects the electronic of the device.
    - Comfortable Din-rail mounting.
    - Succesfully developed software and the ability to update by yourself.
    - The possibility to control all digital and analog signals by VisualBasic macros.
    - Support for the FAULT signals of the servodrives – immediate machine stop In case of failure of any axis.
    - RESET support for the axis drives.
    - Readable LED controls on the front panel for easy installation.
    In the next updates will be support for screws mapping and threading.
    For more info you can visit our website: About us - CS-Lab s.c.
    Download files:
    CSMIO-IP-S Download - CS-Lab s.c.
    Lightbulb Modules and news
    Here you can learn more about CSMIO expansion modules for CSMIO/IP:
    CSMIO-MPG
    CSMIO-IO
    Please also visit CS-Lab news.
    regards
  1. CNC USB motion controller
    By Kroko in forum News Announcements
    Last Post: 01-03-2014, 01:58 PM
  2. Replies: 3
    Last Post: 01-15-2011, 12:19 AM
  3. Is ethernet controller support with linux possible?
    By Menatep in forum CNC Machine Related Electronics
    Last Post: 04-26-2010, 01:29 AM
  4. Ethernet/PCI Motion Controllers
    By 2_many_hobbies in forum Stepper Motors / Drives
    Last Post: 11-12-2009, 04:50 PM
  5. Controller parallel port connected via Ethernet (?)
    By WoodSnarfer in forum CNC Machine Related Electronics
    Last Post: 11-20-2004, 10:48 PM
