603,369 active members*
2,938 visitors online*
Hybrid View
    Sep 2010
    532
    SmoothStepper, Mach3, Win 7
    Is anyone using their SmoothStepper with Mach3 and Windows 7?
    Any problems? I would like to upgrade to Win 7 but would like to avoid any problems.
    I'm not sure if I'll be using a 32 bit or 64 bit machine.
    Any info would help.
    James
    James Harvey
    Harvey Development Corp.
    www.Harvey-Development.com
    36" x 52" CNC Router
    ULS-25E 12" x 24" Laser Engraver
    Jul 2008
    340
    Re: SmoothStepper, Mach3, Win 7
    James, I'm running an ethernet Smootshstepper with Mach3, and 64 bit Windows 7 on my CRP4848 router. Works fine with the exception of a homing problem I am seeing with a slaved Y and A axis. It is a known problem with the firmware and not with the above hardware/software combination.
    I would recommend going with the ethernet smooth stepper since it seems to have fewer problems with noise than the USB version.
    Sent from my Xoom using Tapatalk HD
    CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
    Sep 2010
    532
    Quote Originally Posted by Analias View Post
    Thanks for the info.
    I already have the USB SmoothStepper. It works great, except for the homing problem you mention, but even that doesn't happen very often.
    James
    James Harvey
    Smooth Stepper
    Hi James,
    I am running mach3 version 3.042.040 with a PMDX 126 break out board and a USB Smooth Stepper on a Shopbot retrofitted control. I am using Windows 7 professional and no glitches and no issues with the homing routine. I also use the 2010 Screen Set which I have modified slightly.
    Here is a link to a You Tube video [ame=http://www.youtube.com/watch?v=4WQ8KcTSKyQ]Shopbot PRT Electronic and Software Retrofit - YouTube[/ame]
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Sep 2010
    532
    Quote Originally Posted by HelicopterJohn View Post
    Hi James,
    Here is a link to a You Tube video Shopbot PRT Electronic and Software Retrofit - YouTube
    John
    I'm going to go ahead and update my computer to Win 7. It sounds like it will work just fine.
    James
    James Harvey
  1. smoothstepper stops mach3 after 460 lines
    By Robert Fon in forum SmoothStepper Motion Control
    Last Post: 12-12-2012, 10:20 PM
  2. Problems with Mach3/SmoothStepper
    By JJDennon in forum LinuxCNC (formerly EMC2)
    Last Post: 04-26-2012, 03:31 PM
  3. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
  4. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2009, 12:09 AM
  5. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
