603,780 active members*
3,468 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Electrocraft BRU-200 Drive questions
Page 1 of 3 123
Results 1 to 20 of 53
    Jul 2003
    51
    Hello!
    I have an Electro-Craft BRU-200 brushless servo drive.
    http://www.ab.com/motion/ec/0013-1028-001-B.pdf
    Basically, I would like to know if I'll be able to use this drive at home with a PC and not have to buy anything too expensive to get it working. It was cheap and I have a matching motor for it - it would be nice to get them running if possible.
    The pin information is on pages 24 and 25 of the pdf.
    I'm thinking that it does not take step and direction commands, right?
    Any help would be greatly appreciated!
    Thanks!
    24260
    Hi, My Electro-craft manual shows the command source to be a choice of +/-10v, Step/Direction, Master encoder input, 8 presets, or RS-232/485 commands.
    It looks like you would need the windows based s/w for setup etc.
    This allows you to configure, tune, set up I/O, Diagnostics etc.
    The last I heard they were bought out by Rockwell Automation (Allen-Bradley).
    Al
    Jul 2003
    51
    Thanks for the reply Al - It gave me some hope that I may get this thing running.
    I think I am getting confused because this thing has so many options that don't need.
    I looked at the minimum required connections for the drive (on pages 25-28 of the link above) and that appears to be how the drive was originally set up (the cut cable ends are still connected to the drive and motor). I believe this is how I'll want it also.
    The motor and the encoder should be easy to reconnect. I think the following pins are the +- 10 V step/direction connections.
    P1-1 Enable+ (red wire attatched)
    P1-2 Enable- (black wire attatched)
    Connecting these two pins together enables the DM (drive module?), otherwise, the DM is disabled.
    P1-3 VCS+ (green wire attatched)
    P1-4 VCS- (cable shield attatched)
    +-10 VDC input command signal range with 13.3 K Ohms impedence. Absolute max signal range is +- 12 VDC. + voltage applied to P1-4 with respect to P1-3 results in CW motor shaft rotation facing drive end of motor.
    Could someone tell me how these pins relate to step and direction (or if they do)?
    Could they be activated using the parallel port and an isolation board to change the signal to 10 V?
    24260
    It looks as though P1-3 P1-4 are the input regardless of the type of command, it also appears that the type of command is configurable through the interface program, do you have the program? If so I would suggest running it and see what can be set up. It looks like you will need it in any event.
    You might be able to find a 1-800 number on the web to call, I found in the past Rockwell are very difficult to contact for support.
    Al
    Jul 2003
    51
    I don't have any special software for the drive. It would be nice if I did.
    However, I did notice that in the Drive Module Adjustments section (5.2.2) of the manual that this drive has a "Personality Module" (a special chip) that should make all of the adjustments to the drive to match it with the motor. Thank goodness they match.
    I think that if I could understand the purpose of those four pins (P1-1...4) that I would be better able to know whether or not I can use it (or test it). Here is what I think I understand so far:
    P1-1 and P1-2 are kind of like the on/off switch for the drive - connect them together to turn it on. Right?
    This is the part that I'm far less sure about:
    P1-3 and P1-4 control both the step and direction. So then to step the motor clockwise send a pulse with P1-3 being + and P1-4 -. To step counter-clockwise send a pulse with P1-3 - and P1-4 +. Right?
    ***I had thought that P1-4 was connected to the shield of the cable but it is actually a clear coated wire within the cable.
    Thanks again for your help!
    24260
    Jason, It looks like P1-1 &P1-2 are the enable and have to be connected to run, This I believe will show a green light on the front when ready. The manual is not very clear about the Step/dir command, but in my manual it shows a picture of the setup screens in the setup s/w and it shows one with a choice of input command selection.
    Analog
    Preset
    Master Encoder
    Step/dir
    Step up/Step down
    These are then stored in the personality module ram.
    So I would think that you would need the s/w if you have to change it from a previous configuration.
    It is quite likely that it was used in the analog mode(+-10vdc)
    The manual is not very clear on how you would hook it up in the step/dir mode.
    Do you have an Allen-Bradley office near you? we have one that is very helpfull for these kind of problems.
    To check if it is analog input hook it up and put a varying dc voltage (max 10v) into P1-3 P1-4 it should run.
    Al
    Jul 2003
    51
    The nearest AB distributor is about 300 miles away. I travel that way a few times a year and may have to stop by next time.
    Info about the software seems pretty sparse in the online manual - I'm going crazy skipping back and forth through it.
    Here's what I think I've learned - The software seems to be in the drive module - can this be correct? The drive can interface RS-232 with a Tandy 102 computer (pretty ancient) or RS-422 (Is this the same as 435?) with a VT-52 compatible serial terminal. I think that I can get a VT-52 emulator for the PC.
    I'm going to get or make some cables to hook this thing up and try to put in the variable DC like you suggested. If that works I'll probably be jumping for joy - at least I'd be able to use this setup for something.
    You just might be "the man!" Thanks again!
    Jul 2006
    I need the serial RS485 communicaiotns protocol for ElectroCraft DDM digital servo drive - do you have a programming manual?
    thanks,
    Mick
    Jun 2003
    866
    Al, it seems to me that you are talking about the more recent BRU drives. The BRU 200 and 500 had built in configuration software that you used a terminal program to access. Their recommended terminal is a Tandy 100, wonder if mine still works? I've never seen any reference to step/direction with these drives. Anyone that can tell me how to use it, I would very much appreciate it.
    The personality module on these was a Dallas battery backed ram. The manual mentions EEPROM, but I've only seen the Dallas chips or eproms.
    Dec 2007
    6
    BRU 500 interface
    Would someone help me find a program call EC COMM which help to interface the BRU drive with the servo motor? Someone from Ebay gave me a AB link but I now forgot. My old downloaded file was lost. Thanks
    Dec 2007
    6
    BRU interface
    Have you have any good news talking to the drive? I am having the same problem here.
    QUOTE=Verboten;21283]The nearest AB distributor is about 300 miles away. I travel that way a few times a year and may have to stop by next time.
    You just might be "the man!" Thanks again![/QUOTE]
    Jan 2007
    333
    I've used hyperterminal (rs232) and you simply type a command and the drive answers.
    Dec 2007
    6
    BRU 500 using hyperterminal
    Quote Originally Posted by bborb View Post
    Could you give me more details? What type of command should I try?
    I followed you suggestion and got a blank page. No echo when I typed in so no data can be sent to the drive. Do I got the Set Up page when communication is established?
    Aug 2009
    [i need electro-craft bru 200 for my machines, also guide me about repairing the same
    thanks
    sanjay
    24260
    BRU-200 software
    Is Reliance software needed to set up these drives? and anyone have the manual in PDF, it no longer seems to be on the site now that Rockwell has taken them over.
    Al.
    Albert E.
    24260
    Albert E.
    Feb 2010
    Hi!
    I´m working in a factory where we have a ROMI (don´t know how to say te mchine´s name... I´m from Argentina - in spanish is "torno"). The thing is that this machine has a sevo drive Electro Craft BRU-200. When we try to work with the machine, it makes a emergency stop. When I see the Servo drive, it has the three red LEDs on. Do you know what may that means??
    PS: I can´t see the manual Al.
    Jan 2007
    333
    During power-up, LEDs should turn on for about one second and then turn off. If they remain on and the green LED is on then there is a CPU fault. Drive should be replaced.
    Note: While reset pins (P2-5 and P2-6) are connected, LEDs 2,3, and 4 will remain on and LED 1 will remain off.
    Feb 2010
    Thanks for answering so fast!!
    The red LEDs don´t turn off after a few of seconds... but the green one is off
    The reset pins that you said are not conected. Could I try connecting them??? For reset the driver?? (I´m really sorry, my english´s not so good).
    Feb 2010
    Hi Al,
    Do you have the BRU-200 manual download link?? Because i tried with the link you post but it didn´t work.
    Adi.
Page 1 of 3 123
  1. Electrocraft BRU 105 Servo drive Schematic
    By lekridge in forum Want To Buy...Need help!
    Last Post: 10-25-2019, 03:28 PM
  2. Electrocraft max430 brush servo drive
    By italian-grinder in forum Servo Motors / Drives
    Last Post: 12-11-2010, 05:05 PM
  3. Electrocraft DDM Drive Problem
    By Trevor Archer in forum Stepper Motors / Drives
    Last Post: 09-15-2009, 03:47 AM
  4. Questions about belt drive
    By lonnieh in forum Waterjet General Topics
    Last Post: 05-08-2008, 07:20 PM
  5. Questions on drive setup
    By elogicca in forum Linear and Rotary Motion
    Last Post: 05-15-2007, 06:33 PM
