603,800 active members*
4,444 visitors online*
Results 1 to 6 of 6
Hybrid View
    Jul 2004
    35
    Encoder wiring help needed
    I scored a CMC servo and need help with the encoder wiring. Here's the info:
    Motor: CMC Mod.#ME3528-382C
    Encoder: Digital Devices, Inc.
    Model: M22DM2005LD50AS1
    8 wires connected to a 9 pin connector:
    Green
    Brown
    Orange
    Yellow
    White
    Blue
    Red
    Black
    Will this encoder work with a G320? If so, how do I wire it? If not, what is suggested for replacement.
    Jul 2004
    35
    Well I did some more research and found some info. I think I need to use the red and black for power and ground and then use A+ and B+. How do I determine which ones are A+ and B+?
    24260
    CMC are usually
    Green A
    Brown /A
    Orange B
    Yellow /B
    White Z
    Blue /Z
    Red +
    Blk Com.
    Al.
    Albert E.
    Jul 2004
    35
    Thanks Al. What's the chance of this encoder working with the G320?
    24260
    Quote Originally Posted by dfstrasser View Post
    I believe you will need a separate 5v supply for the encoder, and on what the resolution of the encoder is.
    Al.
    Albert E.
    Jul 2004
    35
    Is there a way for me to determine the resolution?
  1. metronix encoder dealer needed
    By dgalaxy in forum Servo Motors / Drives
    Last Post: 02-27-2007, 02:11 AM
  2. Encoder Wiring Help
    By amitim in forum CNC Machine Related Electronics
    Last Post: 05-02-2006, 10:31 PM
  3. renco encoder info needed
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 09-17-2004, 02:05 PM
  4. Encoder wiring hookup help
    By ty1295 in forum CNC Machine Related Electronics
    Last Post: 07-04-2004, 03:00 PM
  5. Encoder wiring
    By balsaman in forum Gecko Drives
    Last Post: 12-30-2003, 06:01 PM
