587,166 active members*
3,946 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Interact with Heidenhain TNC155B RS232 Interface
Results 1 to 18 of 18
    Mar 2007
    114
    I am having trouble getting the link set up between my PC running TNCremoNT and my TNC155B controller. Im certain the pc end is ok but am unsure what lead to use, the pc has a 9 pin din and the TNC is a 25 pin. Should i be using a lead for software or hardware handshake ?
    Also i am not sure if the controller is set up correctly to see the peripheral device
    Any help would be much appreciated
    richard
    [email protected]
    1121
    re
    first you have to tell us what error you are getting
    to convert to the 9 pin you need to jump two pins and I don't hve that in front of me. The tnc wants to see the handshaking, so is it cts and rts, I think lookin a the diagram on the other thread, pins 4 and 5 on the 25 pin are jumped together, then 2 and 3 are crossed. My old 145 wanted 7 bits, 1 stop bit even parity but I think that is changeable on other controls
    May 2004
    402
    Quote Originally Posted by rrbmachining View Post
    richard
    [email protected]
    If you go back there is a recent thread where I put in the specific cable wiring for this.
    AWEM
    Andrew Mawson
    East Sussex, UK
    May 2004
    402
    Here you go::::::
    Download TNC REMO from Heidenhain's site - set it up and run TNCSERVER
    Make up a cable from 25way TNC151B to 9 way PC as follows:
    (25way TNC) <9 way PC>
    (2) - <2>
    (3) - <3>
    (4) - <8>
    (5) - <7>
    (6) - <4>
    (7) - <5>
    (20) - <6>
    The TNC RS232 interface can exist in three modes - "EXT", "ME", and "FE" selected via the 'MOD' key - it should be in "FE"
    File names & extensions ARE important in block mode transmission. 123.H = program 123 in Heidenhain conversational code and 123.I is program 123 in ISO-Gcode
    When set up like the above it will work - it took me ages to sort it but now all is reliable.
    Andrew Mawson
    East Sussex, UK
    Mar 2007
    114
    Thanks for all the replies, I will give it another try today
    With regard to the last reply from awemawson, shouldn't pins 2 and 3 get transposed in the cable ?. I found that diagram after a lot of searching on page 3-5 of the Heidenhain data interface manual, however there appears to be a discrepency between the two drawings
    richard
    [email protected]
    May 2004
    402
    richard
    [email protected]
    No that's the way 9 and 25 way do it !
    Pin 2 is transmit data on 25 pin and received data on a 9 pin
    Pin 3 is received data on a 25 pin and transmit data on a 9 pin
    Look at Pin Assignments here :
    http://www.camiresearch.com/Data_Com...#anchor1155222
    AWEM
    Andrew Mawson
    East Sussex, UK
    Mar 2007
    114
    thanks for that andrew, that could explain alot, i will give it a try later for sure
    richard
    Mar 2007
    114
    Well im making some proress thanks to all the help i have had, the TNC now seems to talk to the pc running tncserver as the link goes active when i try to transfer a file, however the file does not appear on the pc so i guess the transfer is not complete or corrupt, from what i can see the settings match at the tnc and the pc, anymore thoughts anyone ?
    richard
    [email protected]
    May 2004
    402
    richard
    [email protected]
    TNC server should say 'awaiting request' when it has seen a valid RS232 connection, otherwise it will say 'no connection' Does TNC server start counting up blocks as the transfer starts? Have you set up the folder option on TNCserver to tell it where to put the file?
    AWEM
    Andrew Mawson
    East Sussex, UK
    Mar 2007
    114
    TNC server does say awiting request, the server does have a folder defined but when i try to transfer a file the status goes active for about 5 seconds and nothing happens in the bottom 4 fields of the server window. Maybe its something to do with the file name or extension but as yet i have not worked out how to check this
    richard
    [email protected]
    May 2004
    402
    richard
    [email protected]
    You do have the TNC155 in 'FE' mode and the TNCserver in FE/ME mode don't you? What happens if you try to upload a file? (if in conversational mode the file must be a number with an .H extension and if in Iso mode a number with a .I extension ie 300.H or 300.I - I don't think you can use anything other than numbers for file names, but the number doesn't have to correspond with the program number embeded in the code iirc
    AWEM
    Andrew Mawson
    East Sussex, UK
    Mar 2007
    114
    The TNC155 is in FE mode and the server software set to send/recieve FE. I cant try to upload as i have no files on the server
    richard
    [email protected]
    May 2004
    402
    richard
    [email protected]
    I've sent you some example files in iso code and conversational code
    Andrew Mawson
    East Sussex, UK
    Mar 2007
    114
    I have finally managed to transfer files supplied by andrew but had to change to the ME mode from the FE mode which I was using, anyone know why that should be
    richard
    [email protected]
    Mar 2007
    17
    Red face receive ok but unable to send G codes
    I have read the discussion going on and tried to follow it but unable to achieve the results.I have been working on interfacing my TNC for more than a month.(nuts)
    Now my problems are:
    1. using "ext" mode and cable with wiring shown:
    <DB9>(PC) <DB25>(TNC 155)
    2 <---------------------- > 2
    3 <----------------------> 3
    5 <----------------------> 7
    1,4,6 looped 8,20,6 looped
    7,8 looped 4,5 looped
    and using a DNC software I can receive any G code(already present) from my TNC at my PC but i am unable to send my G codes blockwise to the TNC.I have attached the G codes i received from my TNC. A point to be noted is there is no end of block "*" and no file type of it.
    at the end of received G codes this * is visible on the machine.
    2. I downloaded TNCremo for win98 and when i run it in win98 it gives error before the setup begins i.e "The specified service already exists".
    3. According to the discussion going on the forum i tried to connect the machine in FE mode using Pro NC evaluation version (as i failed with TNCremo)and the wiring diagram given by "awemawson" but again no response.
    It gives error the "End of Block missing".
    when i use MP223 = 1 p
    I am unable even to connect in "ext" mode.
    4. what are the parameters required for using G codes and transfer blockwise.
    Waiting for reply.
    Servocontroller
    [email protected]
    Attached Files Attached Files
    Nov 2004
    3028
    Attached is a technical bulletin from Bridgeport about TNC communication. I added a note about TNC2500 communication using PROCOMM, and a DOS program used with a Radio Shack TRS-80 Model 100.
    George
    Mar 2007
    17
    Thanks George
    Dec 2014
    5
    Re: Interact with Heidenhain TNC155B RS232 Interface
    Hello,
    I have a TNC 155 that I need urgently to connect with my PC. The TNC has a db25 FEMALE port and the computer a usb to rs232 cable that end on a male port. I can't get this to work. Can anyone that has a fully functional setup give me any tips please?
    Greetings
  1. RS232 Interface Question for Meldas M3
    By smirob in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-27-2016, 05:32 PM
  2. Fanuc 10T RS232 interface
    By Lene Madsen in forum Fanuc
    Last Post: 03-09-2012, 04:55 PM
  3. Heidenhain TNC155b Error N-Code Missing
    By ETChipotle in forum Bridgeport / Hardinge Mills
    Last Post: 10-31-2011, 08:00 PM
  4. Interact 1 Mk2 with Heidenhain TNC155B
    By rrbmachining in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2007, 07:18 PM
  5. BobCad to Heidenhain TNC155b problem
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 01-13-2007, 04:19 PM
