603,924 active members*
2,624 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Can Gecko G540 be used with other than paralell ports?
    May 2006
    316
    Will it be possible to connect a Gecko G540 controller with other connections than a paralell port? Are there any electronic converters that can be used for that purpose?
    Apr 2004
    5951
    Re: Can Gecko G540 be used with other than paralell ports?
    The UC-100 connects the parallel port input of the G-540 to USB, which plugs into any modern PC. https://www.cnc4pc.com/uc100-usb-motion-controller.html
    Andrew Werby
    Website
    Nov 2013
    5409
    many motion controllers like an Ethernet SmoothStepper are connected by ethernet to the PC and process the trajectory data (from the PC and Mach or similar) and generate accurately
    timed high speed pulse streams.
    These pulses are presented to the real world in an socket, in the case of the Ethernet SmoothStepper an IDC socket that's pinned out just like a parallel port, ie you could plug
    your G540 straight into it with an IDC-to-DB25 cable.
    The UC100 that's already been mentioned is USB connected to the PC and the output is a DB25 socket which you can plug in directly your G540. If you like that idea then make
    sure you buy a genuine UC100 (by CNCDrive in Hungary) not one of the many Chinese rip-offs on Ebay and Amazon, they are not a patch on the real thing.
    Craig
    May 2006
    316
    Craig
    Thanks for your answer.
    Will the IDC to DB25 cable be a cheaper alternative than the UC-100? When I searced "IDC to DB25 cable" I got a lot of pictures of different flat cable connectors but none of them with an ethernet plug.
    Can an Ethernet SmoothStepper controller be used in combination with Mach3?
    Nov 2013
    5409
    the current price of an Ethernet SmoothStepper (ESS) is $190USD. You'd need an IDC to DB25 cable as well, the same company sells them for about $9.00.
    I believe a genuine UC100 is about $120 USD.
    The UC100 has 17 IO's and the ESS has 51 IO's. So the UC100 is cheaper but the ESS is more capable.
    Both the uC100 and the ESS have both Mach3 and Mach4 plugins and could be used with either.
    Craig
  1. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  2. UC300ETH-UB1 / Gecko G540 / UCCNC Ports and Pins?
    By GEBrown in forum Controller Cards
    Last Post: 08-16-2018, 01:05 PM
  3. Replies: 1
    Last Post: 01-03-2014, 08:58 AM
  4. Replies: 5
    Last Post: 10-20-2012, 04:06 PM
  5. Gecko G540
    By Deb.bosch in forum Stepper Motors / Drives
    Last Post: 03-20-2010, 02:40 AM
