603,914 active members*
2,808 visitors online*
Results 1 to 8 of 8
    Oct 2007
    113
    Sample 4th axis Program please....
    can someone post a sample 4th axis Program feeding x and rotating the A axis
    I went into the wizards and it is only for Straight cuts on gears
    Never played with 4th axis programming and want to try to figure it out
    Dec 2007
    Hello Bullseye,
    To program a fourth axis (rotary) is very simple. Say you want to move 10 inches in X and 720 degrees in A, you would simply program"
    G1 X10 A720 F30
    That's it. In this example, the G1 programs a linear move (interpolated) at 30 inches a minute along the interpolated path. The X moves 10" at the same time the rotary is moving 720 degrees (2 full revolutions) and they both end at the same time.
    If you programmed a G0 instead of a G1, they would move in rapid (non-interpolated) and they would not end at the same time.
    You could program a coordinated three axis move (let's say, X10" Z-3" and A3600 degrees) as follows: G1 X10 Z-3 A3600 F20. In this case it will feed to the right in X as it is feeding down in Z and rotating in A.
    To go the opposite way in A, simply say -3600 instead of 3600.
    Regards,
    Bob66
    Jun 2003
    2103
    Quote Originally Posted by BOB66 View Post
    Hello Bullseye,
    G1 X10 A720 F30
    If you programmed a G0 instead of a G1, they would move in rapid (non-interpolated) and they would not end at the same time.Sorry to disagree, but a G0 is an interpolated move as long as it is done on a controller capable of interpolated moves. The only difference between a G1 and a G0 is the programmed speed.
    Regards,
    Bob66
    The balance of your info is correct.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Oct 2007
    113
    OK..Thats simple enough.......Thanks Guys
    Nov 2009
    16
    example for you
    Nov 2009
    16
    about A degrees
    Hello Bullseye,
    G1 X10 A720 F30
    Regards,
    Bob66
    The A degrees in program must from -360 to 360 degrees,if it over alam will happen.good look!
    35494
    Quote Originally Posted by NguyenViet View Post
    Mach3 allows rotations greater than 360°, so:
    G1 A700 is allowable
    Jan 2009
    114
    How about:
    http://www.cncwrapper.com
    Twenty bucks and saves me a lot of time.
    Fatboy
  1. Sample Nisshinbo g-code program
    By ehab in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-17-2017, 10:59 AM
  2. Need IEI-ISO sample program for Mazatrol 640 T
    By turkaygeyik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2007, 03:03 PM
  3. Replies: 0
    Last Post: 02-03-2006, 12:58 PM
  4. Need Sample Waterjet / Plasma G Code Program
    By BlueChip in forum Waterjet General Topics
    Last Post: 01-14-2006, 03:04 AM
  5. I need sample G code program
    By bunalmis in forum G-Code Programing
    Last Post: 08-24-2004, 09:50 AM
