603,916 active members*
2,165 visitors online*
Results 1 to 11 of 11
Threaded View
arvidb What motor, screw and gearing... 09-03-2004, 09:06 PM
mvaughn Very good reading material... 09-30-2004, 04:25 PM
Jay C First, thank you for this... 01-24-2005, 07:44 PM
alipavsky Web-accessible info 01-27-2005, 08:16 PM
HayTay Check out the attached PDF... 02-14-2005, 04:37 AM
rykegrey I have this Stepper motor and... 02-12-2008, 04:22 PM
springlakecnc I have retrofit over 300... 06-12-2008, 03:27 PM
Daniella1 Thats really great, I have... 03-17-2010, 12:53 PM
marrydavidson10 no, there is no correction to... 04-26-2010, 07:12 AM
15mgtar pease help, I would like to... 08-17-2010, 05:52 PM
15mgtar please help, I want to be... 08-17-2010, 05:54 PM
    Oct 2003
    399
    What motor, screw and gearing should I choose?
    The short answer:
    For a smaller wood and plastic cutting machine (and maybe – maybe! – some light aluminum), several people on CNCzone seems to have had success with 100-200 oz-in (0.7-1.4 Nm) stepper motors direct driving a 5 turns/inch (5 mm lead) ACME (trapezoidal) screw.
    The long answer:
    ... hopefully you can find in the attached file. Please, if you spot any errors or have trouble viewing the file (like missing characters or fonts), write a comment in this thread: http://cnczone.com/forums/showthread.php?t=5639, or use the email address in the file to notify me. Other comments are also welcome to my email address.
    Arvid
    Attached Files Attached Files
  1. What motor, screw and gearing should I choose? v1.2
    By arvidb in forum FAQ of DIY CNC Machine Building
    Last Post: 03-09-2015, 12:47 PM
  2. Help with formulas for gearing servos
    By cnctoolman in forum Benchtop Machines
    Last Post: 04-08-2005, 03:13 AM
  3. What motor, screw and gearing should I chose?
    By arvidb in forum DIY CNC Router Table Machines
    Last Post: 09-03-2004, 10:08 PM
  4. Reduction Gearing & Backlash
    By UKRobotics in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 08:31 PM
