Having problems with tapping a hole. Using a 1-14 3 flute bottoming tap. trying to tap a casting about an 1 1/4. Problem is the machine is thrown into alarm almost to the bottom of the hole. When I get the tap out, it is packed with shavings. I thought maybe a spiral flute might help so I ordered one today. Should be here tommorow. If this don't work, does anybody got anymore suggestions? Maybe tap halfway, pull out and then finish tapping?
Shawn
