Ahhhh, Paint! Is there nothing it CANT do????????
Looks a million bucks mate! This machine is going to be VERY nice when it's finished!!!!!
Keep up the good work,
Chich
Chich
Something crazy happend today, i did one of those findings at the scrapyard that seems impossible. 126 SKF bearings ranging from Ø20 to 150mm. Some of the boxes are dirty and falling apart, but the bearings are brand new and sealed in platic.
Take a guess, how much did a pay and how much is it worth?
From CNC
Pulled myself together to start terminating the wires and misc. stuff. Its those small details...
From CNC
From CNC
As you maybe can see from this pic, i also installed a big fat 6mm2 earthing cable
From CNC
200.00 for the bearings! ?
-Jason
Close, i paid the equivalent of 170$ My first estimate was that there was bearings for around 1000$, but after counting them and looking up the prices it turns out that the total value is 6550$!!!! Talk about finding gold in the trash!
Interested in selling a few? Any of those rated for more then 10000rpm?
any 30206's ?
You can see a full list here http://www.jacobguldberg.dk/Lejer.xls
Sent you a PM
Amazing price! Wow..... WOW!
Did some more designing of the turret. From the picture you may grasp the basic idea of how the live tooling will work. Ill try and use a motor from a powertool. Im only aiming for light cuts and off center drilling. The motor will go on top or behind the turret and connect via belts and pullies to a shaft that again connects to the spindle itself. I have to figure out how the interlocking between the spindle and shaft will work.
From CNC
On another note, i decided to buy a KX3 as soon as i get a job again. Including shipping and the basic such as a vise, clamping set and misc. it will cost me around 3800£ ~5430$, so its definitly going to be the largest investment in this hobby i made so far
Fired up my router today, its been a while. It worked better than i expected. Shouldnt be that hard to guess what it is
From CNC
So are you going to impregnate it with cyanoacrylate for strength?
But seriously, great build, Guldberg. It's great that you can prototype the more involved parts before cutting ferrous metal.
Randy
How did you get the steel to look EXACTLY like wood???????
Awesome! :withstupi
Great prototype idea!
Chich
I did some work on the pneumatic for the turret. I made a quick release coupling next to the power plug.
From CNC
It then runs to the other cabinet where the solenoid valve is placed
From CNC
Finally it runs along with the wires to the top, where its easy accessible along with the gounding wire.
From CNC
On another and more interesting note, ive put down the money for a KX3 along with a precision vise, a coolant system, a clamping set, a 5" chuck and a pair of parallelbars. Total price 3459£...auch. Now im waiting for the beast. Will be sure to make a thread, havent seen many on the KX3
I turned one of the bearings for the turret with a little help from this akward setup. Its a 4-jaw adjustable chuck in a standard 3 jaw chuck.
From CNC
Came out quite nice. I also turned a little plug that fit tight in the hole and in the spindle of my little router, thereby centering it perfectly to drill the holes.
From CNC
I like the look of the combination of steel and brass
From CNC
I also recieved 3 small er16 collet chucks for the lathe turret and a larger er32 R8 for the KX3 mill
From CNC
It kinda sucks that you are not able to edit you own post after only a short periode. Here is the picture that were suppose to be the last in the previous post.
From CNC
I recieved a new shipping of material free of charge from my uncle.
First a load of tool steel. The square is 60x60 and the diameters are 80 and 150. Must have cost a fortune
From CNC
And some more square tubing
From CNC
With all this nice material at hand i decided to make the worlds largest steelwool sponge
From CNC
It only took two hours or so with a carbide insert at 1.5mm per pass, nice blue chips. You can imagine why I made a little dance when one of these landed between my neck and the shirt. Trying to pick it out it burnt through the end of my nail and into my finger
From CNC
From 80mm to ~21mm. I will continue another day, finishing off with a standard insert
From CNC
More pics in the google album
Holy crap!
Such a beautiful project! Looking forward to seeing it in person.
Looks like we have the same priority when it comes to saturdays Workshop time!
This is how it started (except for the length) and how it ended
From CNC
From CNC
The frame for the enclosure
From CNC
I recieved my new KX3, i decided to open a new thread for it to post mods, tweaks and various stuff http://www.cnczone.com/forums/showth...654#post588654
