603,370 active members*
3,555 visitors online*
IndustryArena Forum > Other Machines > Digitizing and Laser Digitizing > Touch probe or 3d scanner/ photo based
    Jan 2005
    37
    I want to carve/engrave on a 3d surface not a flat one and I am not sure a springloaded tool will take care of my needs. So I need the mesh of the parts. I do not need absolutely perfect detail I just need the shape to use in artcam or mastercam. Would you all recommend a touch probe or a 3d scanner? I think time wise I am better off with a 3d scanner. I also think I have a copy of 3dSom around here. Is there any reason a touch probe would be a better choice?
    Visit Dagger and Rose 3D Vector Tattoos at http://daggrnrose.sqweebs.com
    Jan 2010
    23
    I have a Roland LPX250 3d laser scanner for sale....
    will sell for 2900$ and it comes with Pixform
    http://www.stika.com/brochure_LPX250.pdf
    Matthew
    Nov 2005
    20
    3D scanning for sure. Even a lightning fast touch probe would take hours to reproduce surface of any significant size. I spent 2 years exploring and developing processes for reproducing 3D shapes as toolpaths.
    There are a couple of free digitizing tools depending on your patience level:
    www.david-laserscanner.com
    http://mesh.brown.edu/byo3d/source.html
    Or you can use one of the commercial scanner$. I've been using FlexScan3D with fantastic results for my own projects: http://www.3d3solutions.com/
    I've got a little more write up on 3D scanning, CNC retrofits, and other fun projects at my website:
    www.bluegalaxydesign.com
    Keep in mind, scan data is an exact reproduction of the original surface, and depending on your process, may result in not-so-smooth G-Code and machining. To create true CAD surfaces takes a little more finessing.
    -Dan
  1. Touch Probe
    By Babba in forum Syil Products
    Last Post: 03-11-2022, 04:36 PM
  2. homemade 3D touch probe?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 03-09-2021, 02:58 PM
  3. Heidenhain TS-112 touch probe
    By rooj65 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2017, 10:01 AM
  4. TP100 Touch Probe help!
    By Hambonin in forum Community Club House
    Last Post: 04-16-2009, 11:24 PM
  5. Z axis touch probe
    By Swede in forum FlashCut CNC
    Last Post: 08-29-2007, 06:09 PM
