603,314 active members*
2,663 visitors online*
IndustryArena Forum: Turning
Page 3 of 18 1234513
Threads 41 to 60 of 351
Discuss problems, tips and techniques for turning.
  1. Need ideas
    Started by danrandall, 08-18-2022 04:00 AM
    back, job, machine, screw, spindle
    08-18-2022, 03:45 PM Go to last post
  2. Trapezoidal thread Tr.48x6
    Started by MartinDK, 07-28-2022 04:01 PM
    07-29-2022, 01:47 PM Go to last post
  3. Miyano 34T Lathe B axis
    Started by Nodink, 12-12-2018 05:58 PM
    07-29-2022, 09:58 AM Go to last post
  4. 10"/250MM Lathe Scroll Chuck
    Started by tomross, 03-31-2022 07:08 PM
    chuck, dims, find, jaw, jaws
    07-27-2022, 03:13 AM Go to last post
  5. 3" Male NPT Single Point with G76
    Started by 07BlackOps, 07-11-2022 04:45 PM
    07-20-2022, 01:53 AM Go to last post
  6. teaching question
    Started by FUBAR62172, 07-04-2022 11:13 PM
    07-05-2022, 09:16 PM Go to last post
  7. Question Fanuc Lathe system T codes
    Started by KovatechCNC, 11-14-2019 03:38 AM
    code, fanuc, lathe, lathes, read
    07-03-2022, 11:57 PM Go to last post
  8. NEED ADVICE - grooving OD
    Started by jeph45, 09-02-2020 07:28 PM
    0.5”, advice, cnc, i’m, starting
    07-03-2022, 09:58 PM Go to last post
  9. Tool Nose Radius (formula)
    Started by trynew, 01-20-2021 03:41 PM
    07-03-2022, 08:59 PM Go to last post
  10. Threading 17-4 PH SS
    Started by BlaznLow, 12-02-2021 10:44 PM
    17-4, in/rev, insert, rpm, running
    07-03-2022, 08:35 PM Go to last post
  11. Mill-Turning - need settings for brass
    Started by scott216, 10-23-2019 01:54 PM
    brass, mill-turning, rpm, speeds and feeds, tormach
    06-23-2022, 01:11 PM Go to last post
  12. Can’t get Mach 3 g54 to start at zero…
    Started by BrandonBov, 03-22-2022 03:53 PM
    cnc, fusion, lathe, mach, mach3
    03-22-2022, 03:53 PM Go to last post
  13. GSK 980 TDC Control help.
    Started by NRM2019, 12-03-2019 03:11 PM
    03-21-2022, 03:47 AM Go to last post
  14. LNS service parameters password
    Started by hotiron, 03-12-2022 05:53 PM
    access, lns, parameters, password, service
    03-12-2022, 05:53 PM Go to last post
  15. 2" diameter Acme 2 TPI Stub thread help
    Started by Hightower1, 02-26-2022 02:05 AM
    data, form, stub, thread, tool
    02-26-2022, 02:05 AM Go to last post
  16. Post HFT function on STAR-SR20J
    Started by jakob2796, 05-27-2021 08:03 PM
    02-17-2022, 04:51 AM Go to last post
  17. Gloat post
    Started by Robbiemstevens, 11-19-2021 10:17 AM
    chase, cnc, managed, saved, woop
    11-19-2021, 10:17 AM Go to last post
  18. Red face Okuma Act 3 FANUC 10 TF with FAPT.
    Started by JonathanJones, 06-18-2019 02:36 PM
    fanuc 10tf, fapt, mtf paramaters
    11-19-2021, 05:19 AM Go to last post
  19. Can't Reference EMCO 360 Turn
    Started by Greitz, 10-19-2021 10:54 PM
    10-20-2021, 06:08 PM Go to last post
  20. Post Churchill cnc lathe fanuc t40??
    Started by kobra_wizzard, 02-21-2019 06:46 PM
    10-08-2021, 09:05 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
