603,836 active members*
3,169 visitors online*
Results 1 to 7 of 7
    Jan 2004
    190
    what is needed for cnc
    I am building a conversion and need to know what electronics I need to purchase or build for the cnc part.I do have 4 servo motors ordered I want x,y,z,a (a being my rotory table ) and also have never had any kind of cnc experiance but am prepaired to learn.I have a smithy 3n1 and am going to buy a HF mill for the conversion any help will be apriciated thanks.
    this is my website and some things I build www.lambertsrc.com
    thanks Kenneth
    www.lambertsrc.com
    Mar 2003
    2139
    What kind of servo's did you buy?
    Eric
    I wish it wouldn't crash.
    Mar 2003
    6855
    Nice site your my kind of guy, I fly R/C planes and helis.
    Jan 2004
    190
    clifton dc 30v that were 9.95 that were on another post
    I haven't been into the heli seen just planes but mostly building engines but now i want to do cnc
    thanks Kenneth
    www.lambertsrc.com
    Mar 2003
    779
    Ah, the "Cheap servo's"
    Get an encoder on them. I used the E2 from USdigital. These servo's have a nominal terminal voltage of 36VDC. Get or build a power supply that is 36VDC @20-25 amps.
    Get 4 Gecko G320's
    Place these into a metal box with a fan blowing on the Gecko's
    Get or make a LPT breakout board. Connect the proper pins from the 25 pin LPT connector to the Gecko's (check your controller software for proper pins)
    Connect the servo motors leads to the Gecko's
    Connect the encoder to the Gecko's
    Get +5VDC to the Gecko's (From PC or external wall wart)
    In a nut shell, there you are.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Jan 2004
    190
    yes that sounds simple except need to know what a break out board is and how to make one and what type software is needed. this is going to be a learning thing for me (something I always wanted to do but have never had the chance)
    thanks Kenneth
    www.lambertsrc.com
    Jan 2004
    87
    Me too! I will be reading.
    Mark
  1. Precautions needed while moving CNC Machines
    By cwww in forum DNC Problems and Solutions
    Last Post: 03-19-2006, 06:28 AM
  2. 2 parts needed: gear and insert
    By SimonArthur in forum Employment Opportunity
    Last Post: 03-12-2005, 11:20 PM
  3. What's needed for complete setup?
    By LeeWay in forum Gecko Drives
    Last Post: 03-09-2005, 03:38 PM
  4. Advice needed: Buying a CNC vs retrofitting a manual
    By jkeyser14 in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 07:03 PM
  5. Replies: 5
    Last Post: 09-29-2004, 03:23 AM
