603,326 active members*
3,194 visitors online*
    Mar 2007
    60
    Wiring done,firing up the system
    I think my wiring is complete.
    Other than making sure the wiring is correct, are there any precautions I should know about before I fire it up? Any particular order in turning on power? Should all the motors be connected or can I test individually? If I have only one motor connected to one driver, should I disconnect power leads to the other drivers or will it be fine?
    I set the 4030 drivers to 1.2amp and 1/8 step for testing - (I really don't know what they should be set at yet)
    I don't want to blow anything up the first time I power up.
    Jump in with any words of caution.
    Thanks.
    Dec 2006
    532
    power the computer up first, make sure bob is connected, than power up your 24v/5v supplies. Shouldnt matter if you have one or 4 motors connected, i ran with only two and everything was ok. I have mine set at 3A. Good luck
  1. Wiring help
    By watsonstudios in forum Automation Technology Products
    Last Post: 06-13-2007, 05:32 AM
  2. wiring it all together
    By russell in forum CNC Machine Related Electronics
    Last Post: 08-22-2006, 03:08 PM
  3. CNC wiring?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-18-2006, 09:44 PM
  4. system Wiring diagram, BMI Trak W/LCD needed
    By bsllc in forum Bridgeport / Hardinge Mills
    Last Post: 02-17-2006, 10:18 PM
  5. P5 Wiring
    By tintruder in forum Servo Drives
    Last Post: 02-03-2006, 06:13 PM
