603,780 active members*
3,125 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Yaskawa servo coupler?
Hybrid View
    Aug 2011
    15
    Picking up a 1999/2000 Kitamura Mycenter-0. Unfortunately the shop owner sent in the X-axis servo motor to be repaired and when he did ho left the coupler for the servo motor attached to the motor, he then decided to offload the mill to have room for a new machine after getting the quote back from the repair company and told them not to worry about sending the motor back because he didn't want to pay for return shipping. I pointed out the fact that the spare motor that he had for the machine (also a bad motor) did not have the coupler on it. and ho contacted the company that he sent the motor off to for a repair quote.according to them they went ahead and scrapped the motor. So now the machine has a bad X-axis motor without a coupler. Does any one have or can get a picture of the motor coupler that I can use as a reference. There are several motors on e-bay that match the part number for the one on the mill that include the coupler and I want to make sure I am getting the correct one.
    Thanks in advance.
    Mike
    Sorry I forgot this is a Yasnac/Yaskawa machine.
    Re: Yaskawa servo coupler?
    Quote Originally Posted by mike96 View Post
    Thanks in advance.
    Mike
    What is the exact X-axis servo motor model number?
    For example, Fanuc A06B-0128-B075, Yaskawa, Mitsubishi, etc
    Aug 2011
    15
    They are Yaskawa USAGED-09A21.
    There is a motor currently available on ebay that was pulled from a Matsurra ra-g1with the coupling still on it, I'm curious if the coupling will work.or maybe made to work...
  1. 1979 model SL-1 yaskawa servo drive and servo problem
    By Redzilla in forum Mori Seiki lathes
    Last Post: 10-31-2016, 07:21 PM
  2. shaft coupler servo motor cincinnati milacron
    By hotrunner in forum Cincinnati CNC
    Last Post: 04-15-2016, 05:32 PM
  3. Replies: 0
    Last Post: 10-21-2014, 09:29 PM
  4. Help removing servo coupler
    By jfong in forum Maintenance DIY Discussion
    Last Post: 01-27-2014, 06:34 PM
  5. Change from yaskawa servo to delta servo
    By sachin.kumar in forum Servo Motors / Drives
    Last Post: 11-02-2012, 06:31 PM
