603,890 active members*
3,056 visitors online*
IndustryArena Forum > CAM Software > Mastercam > HELP WITH MASTERCAM (machine definition & postprocessor)
Results 1 to 4 of 4
    Oct 2012
    13
    Hello I'm new to mastercam so here's my question :
    I have mill 3+1 axis its configuration is like this engraving machine
    3 (XYZ) axis in which moves spindle and one ROTARY (A) axis in which is rotated the handle on which I mount the material that I use. can you explain which machine definition to use? or how to make my own? and if I will build my own how to get postprocessor for that?
    THANK YOU IN ADVANCE.
    Sep 2012
    why dont you go to emastercam and download the MPMaster post! that should help..
    Oct 2012
    13
    Thank you for anser. but as I'm new in mastercam can you explain bit further?
    if I understood correctly I've to downloa posprocesor from emastercam instal it and then create machine definition for my machine yes?
    Oct 2010
    317
    Machine Type > Mill > Manage List > Select "Generic Haas 4X Mill"(Select the one with MM for metric) > Cick "Add" > Green Checkmark > Machine Type > Mill > Generic Haas 4X Mill should now be in the list.
  1. TL-2 machine definition for Mastercam
    By jefffalk in forum Haas Lathes
    Last Post: 07-26-2017, 10:37 AM
  2. Machine Definition
    By dherberger in forum Mastercam
    Last Post: 07-18-2011, 03:18 PM
  3. FLA 100 Machine definition
    By Justin Cavender in forum DIY CNC Router Table Machines
    Last Post: 02-13-2011, 08:54 PM
  4. Machine Definition help
    By drupillow in forum Mastercam
    Last Post: 04-24-2010, 12:04 AM
  5. postprocessor for adapted cnc machine ( mastercam )
    By vimafeje in forum Post Processors for MC
    Last Post: 11-30-2009, 01:23 PM
