603,898 active members*
3,663 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > need help calculating torque in rack&pinion system.
Results 1 to 6 of 6
    Jul 2013
    4
    Hi All, I need help to calculate a required torque for motor in the rack and pinion system.
    My application is look like the picture below. It is a rack and pinion system which the motor is used for moving the carrier in x axis. and the force load is in y axis.
    I have known that to calculate the torque is just use T=F x r but in this case, I dont know how to calculate F.
    Please help. Thank you in advance.
    Mar 2003
    35494
    How much weight are you moving, and how fast do you want to accelerate?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2013
    4
    load 5kg and i want it move 1meter in 10second
    thank you
    Apr 2006
    3206
    You're confusing torque and horsepower. You're saying you want to move a 5kg load 1/10meter in 1 second... That's force vs distance vs time, whereas torque is force.
    ie: You want to torque a bolt to 2.2ft-lbs.... you put a force of 2.2lbs at a distance of 1ft on a bolt and you've got it, even if it takes a week. If you want to lift 550lbs 1ft in 1 second, you'd need 1 horsepower, so you can see that's the rate of change.
    Mar 2003
    35494
    You also need to provide the pinion pitch diameter, and whether there's a gear reduction or not.
    Gerry
    Jul 2013
    4
    Ok, I am a bit confusing sorry all. also bad in physics T__T
    let say I want to move from motionless to 100mm/s. so the acceleration = (100-0)/1 = 100mm/s2 right? please educate me.
    and my pinion diameter = 20mm. Weight in Y-axis is 5Kg.
    so how can I calculate the F along X-axis?
    more question please. The module of rack&pinion how to choose it? the bigger number of module means the bigger capacity of load. am i right?
    Does the bigger no. module will reduce the resolution of the system?
    Thank you ger21, fizzissist. appreciated you all.
  1. Highly accurate rack and pinion system
    By davtuner in forum Linear and Rotary Motion
    Last Post: 03-14-2014, 04:35 PM
  2. rack and pinion system?
    By cwpeters in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2011, 11:58 AM
  3. the rack and pinion machine motor torque
    By podolskiy in forum Mechanical Calculations/Engineering Design
    Last Post: 06-23-2010, 01:19 AM
  4. Need help calculating steps per unit (rack and pinion)
    By idtkid in forum Mach Software (ArtSoft software)
    Last Post: 04-27-2009, 07:06 PM
  5. Opposing torque Rack & Pinion anti-backlash system?
    By Cliff567 in forum Linear and Rotary Motion
    Last Post: 01-26-2009, 02:38 AM
