587,787 active members*
3,370 visitors online*
    Aug 2009
    136
    Reverse Motor Direction
    can some one help me. i have 2 y axes moter but i need one to turn the other way i'm doing belt driving. can some one help me
    Mar 2003
    35538
    Are you using Mach3? And how are they connected? Are they slaved?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2008
    226
    You can reverse the slaved axis in the Config>Homing/Limits... or DIR Low Active in Config>ports and pins , or reverse a phase of your stepper. (switch just two wires on one phase of the motor.)
  1. How can I reverse the direction of one motor using turbocnc?
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2008, 01:23 AM
  2. Reverse Stepper Direction, Wiring Questions...
    By Patrick_M in forum Hobbycnc (Products)
    Last Post: 10-02-2008, 07:36 PM
  3. Reverse direction?
    By HakBot in forum G-Code Programing
    Last Post: 11-19-2007, 11:30 PM
  4. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
  5. Replies: 0
    Last Post: 11-01-2005, 03:51 AM
