603,802 active members*
3,992 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Bringing the Art of Scraping into the 21st Century?
Page 2 of 6 1234
Results 21 to 40 of 108
  1. #21
    Feb 2006
    1051
    Quote Originally Posted by Pres View Post
    How "Fred" (as in Flintsone) is that?
    If files were meant to be used with handles, they'd come with handles! :rainfro:
    Best regards,
    Randy
  2. #22
    Mar 2005
    1673
    Quote Originally Posted by Mcgyver View Post
    John, just notice the file scrapper - now i know why you abandon the scraper for dremel - that would be killer using a scraper that short......or did it start out as a 14 bastard and that's how much you had to sharpen it try forging one out of a full size file, its a lot easier.
    The scraper you see in the picture started out life with 7” (I read somewhere that 6” was ideal) of blade. You just need to ask Warren aka itsme about these mills as they need a large amount of material removed. I made and am using a new one about 12” long now.
    John
  3. #23
    Mar 2006
    357
    I have been considering doing a detailed description with picture of the whole job start to finish but am unsure if there would be enough interest to go to what would be a lot of trouble. If this might interest you please post and let me know.
    I think that is a great idea!
    Steve
  4. #24
    Jul 2007
    195
    question #1 What is flaging?
    In the old days when you finished the fitting part of the job, a good millright would "flag" the surfaces. The reason for this was to retain oil on the surface.
    It's done by putting the edge of the scraper down on the surface then banging the handle with one hand while turning the scraper with the other hand. The mark left on the surface (if you do it right) looks like a flag blowing in the wind.
    question #2
    Why do you use file handles?
    The first reason is the end of the file is not made for your hand it's made for a file handle. If you use a file on a lathe without a handle you could get hurt real bad if the file kicks back on you. And second I was taught that the oils from your hands made the swarf stick to the file and made it not cut as well as a clean DRY file. Most people think that a file is an abrasive tool, it's not. It's a lot of small cutters in a row and it works better if the swarf falls off.
    If you clean your file and flush it with solvent then dry it. the file will cut much better then a oily dirty file.
    Be carefull what you wish for, you might get it.
  5. #25
    Mar 2005
    1136
    Quote Originally Posted by JROM View Post
    yup, saw this happen a few times. Each time it was caused by the object thrown by my German high school machine shop teacher when he caught someone filing in the lathe
    JROM, I agree with you, those newer to the craft (not a trade for me) would do well to learn how to use files. About as important as being able to tap a hole imo
  6. #26
    May 2005
    1810
    ... would do well to learn how to use files. About as important as being able to tap a hole imo
    Or better - properly de-burring their parts!
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
  7. #27
    Feb 2006
    1051
    That is the one situation where I always use a file handle (the only thing I file in the lathe is breaking the edge of a piece I've turned.) And though I'm right-handed, I use the left-hand filing technique so if the file does catch and is flung, I'm not in its path.
    Best regards,
    Randy
  8. #28
    Mar 2005
    1673
    And I thought we were discussing “hand scraping” here?
    So if I told you that “flaging” as you put it or “flaking” as my grandfather put it (a “hand” for over 40 years) is done for show and is actually detrimental to a bearing way, you would already know that?
    John
  9. #29
    Jul 2007
    195
    I like my version better. I've seen alot of high end machines over the years with "flaged" ways and I don't think they went to all that trouble for show.
    Also when you use abrasives on soft metal some of the rocks always get embeded in the metal........not to good for a bearing surface. Except for surface grinders grinding hard material.
  10. #30
    Mar 2005
    1673
    I’ve just been Googling and found this. http://www.desktopcnc.com/swarf/frosting.htm Seems to confirm what my grandfather told me.
    So how do they stop grains from a grind wheel from embedding into ways finished on a surface grinder "cast iron" which are not a “hard” metal?
    John
  11. #31
    Feb 2006
    1051
    Quote Originally Posted by Oldmanandhistoy View Post
    My apologies, John, for diverting your thread.
    Please explain further, John. From what I have read on scraping, the flaking creates mini lubricant pockets to avoid the moving part wringing onto the stationary part of the bearing. Is that wrong, or is there something in the flaking process that disturbs the surrounding surface?
    EDIT: You must have posted the immediately preceeding entry while I was composing this one. I withdraw the question.
    Best regards,
    Randy
  12. #32
    Jul 2005
    12177
    ....would do well to learn how to use files. About as important as being able to tap a hole imo
    Oh come on: tapping holes is nowhere near as boring as filing . Somehow as an apprentice I successfully avoided ever having to do the filing thing to make a square peg and hole that would not allow a 0.001" feeler gauage in the gap. And I still hate filing or scraping.
    EDIT: I guess I have to apologise for diverting your thread. And also commit the sin of saying I think your Grandpapa was wrong; at least based on what I was taught. The nice mottled flaking is done in a nice symmetric pattern for visual effect but the underlying purpose is to provide lubricant reservoirs.
  13. #33
    Mar 2005
    1673
    Quote Originally Posted by ProtoTrains View Post
    No need for an apology I was jesting.
    John
  14. #34
    Mar 2005
    1673
    Quote Originally Posted by Geof View Post
    I think it would be wise for me just to leave this thread to you guys .:wave:
    John
  15. #35
    Mar 2006
    357
    Well John, I tried your method today. Works excellent.
    Very very fast once you get the hang of it. Very light touch as you say. There is no muscle work whatsoever using a grinder.
    I held the dremel with a very very light feel. I pretty much just held at it's center point in my hand so it would remain level. Then just lightly touched down to the hi spots with no hand pressure at all once the parts were getting close.
    It is quite different than hand scraping that is for sure and I can see where somebody with a shaky hand could get into trouble fast. But I found it very easy after an hour or so of practicing.
    These are not bearing surfaces so they just needed to be nice and flat.
    I'll post 4 pics and explain them.
    Pic1 is the top of the headstock riser block that the head stock mates to, which I had made flat to the surface plate.
    Pic2 is a before shot of the headstock that sits atop the headstock riser- So the head stock would be made flat using the head stock riser block top surface as the reference.
    Pic 3 is the head stock surface after using the dremel for about an hour referencing it to the headstock riser surface.
    Pic4 was a final test and it is very interesting to note. This is the surface of the head stock AFTER being made flat to it's reference surface the head stock riser. I placed the head stock on the surface plate this time and note the pattern is now reversed. The high spots are exactly where the areas were never touched with the dremel.
    Very very effective method using a dremel IMHO if you can handle the very light touch that is needed to make it work.
    Steve
  16. #36
    Mar 2005
    1673
    Just a quick note on this comment; because I am willing to learn and question what I believe to know I took a microscope to my way surfaces. Not the most high tech gear but good enough IMVHO to check JROM’s point. At fifty times magnification there was no sign of embedded grit from the abrasive belts. I put this down to the fact that they are very well adhered and the very low cutting force. Because of the high contrast between the two materials it would have been easy to see unless they are so microscopic and I really needed a probing electron micro scope which I have sent away for an overhaul so was unavailable
    Quote Originally Posted by S_J_H View Post
    Hi Steve,
    Please to here it went well. Thanks for posting.
    Did you use an abrasive belt on a rubber bobbin or a grind wheel?
    I use the former and do know there are at least two different grit grades (could be more?). If you are using the same and are finding that you are needed too light a pressure to control the removal rate you could use an already partly used belt or give it a quick spin on something like concrete to blunt it a bit. Obviously by the sounds of things this is not a problem for you but would help anyone else who is a bit heavy handed.
    John
  17. #37
    Mar 2006
    357
    John, I used those tiny little abrasive bands on the rubber bobbin. I also removed the small outboard steel washer on the rubber bobbin and this gives a little smoother action.120 grit works pretty good for fast removal.
    I did my rail risers today on the lathe bed. All I can say is this method will very quickly get you a nice flat surface. One thing though, sure is messy!
  18. #38
    Sep 2006
    6463
    Fellow citizens, the thread is "Bringing the art of scraping into the 21st century", and no way will I comment on the use of an angle grinder or other abrasive method to ensure accurate fits in machinery.
    The next thing someone will advocate using a sheet of wet & dry paper on a paving stone to lap a machine part flat.
    Dear John, go back to bed, read a good book, but don't propose bodge methods as a synonym for skilled work practice for the 21st cent.
    Anybody who grinds cast iron is asking for trouble.
    Cast Iron in it's natural state is machined and scraped, but when it's flame hardened it can only be ground.
    One last thing on bluing a surface plate, if the blue transfers to the part being tested and shows up as blue it's TOO thick and just smears everywhere, it should be applied sparingly and when transferred should show up as a GREY marking on the part.
    The final test for an accurate surface is 25 dots of contact per sq inch.
    Ian.
  19. #39
    Mar 2006
    357
    Ian,
    You probably can't control the rotary tool with as much precision as a skilled hand scraper and it is certainly limited in use for surface type( dovetails would be very difficult to use it on) but for a hobby level work you can still beat the heck out of the machined finish done with one of our hobby mills. I'll estimate flatness to well under .0003" no problem and done very quickly. You can dust off a very small amount of material with the right touch.
    In my case I am only flattening clamping surfaces not a bearing surface.
    The surface is very good now.
    I'll have to get a .0001 indicator and test out just how much control I can get in material removal with the rotary tool.
    In my pics I deliberately used a heavy coat of hi spot blue just for the pics. In reality my flats show only small speckles that are very difficult to see.
    Steve
  20. #40
    Mar 2005
    1673
    handlewanker,
    I could sit here and type quite a few word is response to your post but I will not. I certainly will not insult you with a comment like “Dear John, go back to bed, read a good book, but don't propose bodge methods as a synonym for skilled work practice for the 21st cent”. At the end of the day I can not respect the opinion of a person who is not at least willing to entertain the fact that there could just be another way of doing things. I could say “give it a try and see for your self” but I know for a fact you would not. All I will say is “what can’t speak can not lie” and ask you is the world flat or round?
    Regards,
    John
    At this point I could go into detail describing the accuracy I have archived with my method (burn him, burn him lol) but will just say “try it for yourself, get a piece of scrap and give it a try then judge for yourself”. It will require practice and some experience to achieve good results but that has to be expected. Or if you read through this thread and decide it’s not worth trying and cannot possibly achieve good results because other members say so then move on and good day to you.
    This will very likely be my last post in this thread unless some one has a genuine question or an opinion that they are at least willing to discuss in a civil manner. I have nothing to prove here all I was trying to do was help others. The fact that one member gave it a try and was happy with his results has made all my posts in this thread worth it.
    John
Page 2 of 6 1234
  1. GE mark century 2000 drip feeding
    By ncmas in forum DNC Problems and Solutions
    Last Post: 10-11-2011, 12:56 PM
  2. Mark Century 2000 Dnc Problem
    By ozgurm in forum DNC Problems and Solutions
    Last Post: 02-18-2009, 06:22 AM
  3. Century 82050 Question
    By meerkatguy in forum Waterjet General Topics
    Last Post: 11-15-2006, 09:41 PM
  4. More Scraping
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2006, 11:53 AM
  5. Bringing objects together in V19 & general questions
    By rustyolddo in forum BobCad-Cam
    Last Post: 07-31-2004, 03:14 PM
