CNC-STEP
1805
CNC-STEP
1805
5 facts about T-Rex CNC milling machine
MarketingCNC-STEP GmbH & Co. KG on June 2, 2022 at 8:35 AM
5 facts about the T-Rex portal milling machine.
Did you know that ...
  1. the machine is optimally controlled by our in-house KinetiC-NC software.
  2. the vacuum table is fixed in the machine and does not cost extra.
  3. a Z-axis with 400mm clearance is available as an option, which allows milling of components up to a height of 300mm (engraving up to approx. 350mm).
  4. that we can work with the T-Rex across different materials. Materials such as wood, plastics, non-ferrous metals, and steel can be CNC machined in sheet form in various shapes and sizes.
  5. the T-Rex is even available in special sizes such as 8000 x 2600mm.
