CNC-STEP
1805
CNC-STEP
1805
Clamping method: vacuum table
MarketingCNC-STEP GmbH & Co. KG on November 26, 2020 at 10:30 AM
If you work on your CNC machine mainly with elastic and thin materials, a vacuum table is the appropriate clamping method.
That not only saves time during clamping but also allows you to work even more precisely, as the materials can be clamped without vibration.
Our vacuum tables are available in different sizes from 220 x 320 mm to 1500 x 1200 mm.
