CNC-STEP
1805
CNC-STEP
1805
Plastic milling cutter
MarketingCNC-STEP GmbH & Co. KG on April 28, 2022 at 8:40 AM
Our plastic milling cutter for Plexiglas has exceptionally sharp cutting edges and a right-hand twist (down-cut). Due to its design and the polished flute, the end mill tends to stick less and offers excellent chip removal.
That makes it ideal for milling work in plastic, PMMA and Plexiglas®. It is available in cutting edge diameters from 1-10mm.
