CNC-STEP
1805
CNC-STEP
1805
flowJET Water Jet Cutter
MarketingCNC-STEP GmbH & Co. KG on July 30, 2020 at 9:30 AM
Our new flowJET Water Jet Cutter provides 3800 bar power and thus can cut a 150 mm high anvil. The flow rate of up to 4.0 L/min is also quite impressive.
We offer the CNC water jet cutter in different variants. So you as a customer have the choice between pure water or abrasive cutting and a 15 or 30 kW high-pressure pump.
Follow this link to learn more about the flowJET.
