CNC-STEP
1805
CNC-STEP
1805
Milling Ureol
MarketingCNC-STEP GmbH & Co. KG on May 13, 2021 at 9:30 AM
The Ureol we milled for test purposes for an interested party, to see how good the milling result is after one milling pass. Because we chose a slightly higher feed rate and a tapered radius cutter (r= 0.5 mm), the milling paths are still slightly to see.
By optimizing the milling paths or a subsequent finishing, you can achieve a higher quality surface finish.
We are satisfied with the result!
If you would also like to know how good your chosen material can be machined on the CNC-STEP machines, please arrange a demonstration appointment. Then we can show you live the performance of our CNC routers. Bring your material and a milling file to this appointment so that we can directly implement your wishes.
