CNC-STEP
1805
CNC-STEP
1805
Milling and laser engraving with one CNC machine
MarketingCNC-STEP GmbH & Co. KG on April 29, 2021 at 9:30 AM
Laser engraving and milling with a CNC machine?
Our partner Denny König shows what you can "get out" of our High-Z S-1000/T milling machine.
He pre-roughed oak wood with an 8mm milling cutter and did the fine machining with a 3mm milling cutter. Furthermore, he used our 5.5-watt laser module.
The result is a company sign with engraving, lasered QR code and concave lettering.
The conversion of the CNC milling machine is effortless and can be done in just a few steps.
This video on the light arch project shows how easy it is to switch from spindle to laser and what our machine can achieve.
